Question about HP Laserjet M2727nf Multifunction Printer
Restart My MF2727 is constantly re-booting, but only when it is connected to my computer. The connection is with USB. I have applied the June 2011 firmware upgrade to the MF2727, but it has not helped. My computer is running W7 (32bit), and I have installed the March 2010 Full Solution software, 5.2 AM-EMEA1. When the USB cord is not connected to the computer, the printer can be on for the whole day and never re-boot. When the USB cord is connected, then regardless of what I am doing on the computer (working or the machine is actually idle), there is irregular re-booting of the MF2727, sometimes as frequently as 7 minutes, sometimes as infrequently as every hour. Any suggestion other than re-installing the software? thanks,
SOURCE: My computer (PowerMac G4) doesn't communicate with my printer
Get an add-in USB PCI card.  My peripherals work on my G4.  These PCI cards will have 2.0 speed.
Posted on Nov 20, 2007
gewiz
  • 1271 Answers
SOURCE: Unable to install HP F380 drivers on Vista
well first of all uninstall the driver or drivers by going to the Control Panel, programs etc, if there driver is installed . Reboot, Now can you try another usb lead ? http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=&cc=us&lang=&product=1128296 now look at the post called Critical Update to Correct a PC to Printer Communication Issue download the HP Full Feature Software and Drivers install and connect the printer when prompt. Regards GeWiz
Posted on Jun 15, 2009
SOURCE: HP Color Laser Jet printer CM1312nfi: scanner no
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Posted on Oct 17, 2010
puertobori
  • 7733 Answers
SOURCE: HP Deskjet F4480 will not
Windows 7 comes with basic driver built into the operating system (in-OS driver). With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. However, using the workaround procedures in this document, you can still print from a software program. You can also import and view images on a memory card, if your product has a memory card slot. When you connect the product to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Follow these steps to install the basic driver in Windows 7.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the product and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use the following workaround procedures instead.
For more options go to LINK .
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
SOURCE: After firmware upgrade the HP 4015x will not boot
I had the same problem. HP Pro Support advised me to
deinstall the additional paper tray and the toner.
and reapply the firmware update 3 times.
It sounded stupid to me but it worked!!!
Be sure to use usb connection and wait 30 min between progress.
1 st time - no paper tray, toner, wait 30 minutes
2 nd time - no paper tray, wait 30 minutes,
3 rd time - all together now, wait 30 minutes
I hope this will help you and others,
Arthur
Posted on Nov 30, 2010
How to resolve constant boot loop in samsung galaxy fame
use usb connection from your phone and your computer to upgrade your phone's operation system from the samsung website
Jan 26, 2016 | Samsung Cell Phones
Samsung contact number
As soon starting of computer, press F1. You might be find options for boot up. Boot up is default from CD Drive. Change booting option to USB. Connect your USB. Restart the computer.
Jul 19, 2014 | Samsung Series 7 DP700A3D-A01US 23.6"...
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios settings.....in bios settings change the boot priority to USB flashdrive....save and restart before you restart connect your flash drive to ur laptop......it will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Gigaset 567 wireless router. unable to connect from desk top to laptop
try to disable the antivirus software and try to connect again, if this doesnt work try to go to safe mode w/ networking
to go to safemode w/ networking you can try this options:
when using windows XP, Vista and Windows 7. try to restart the computer as soon as the computer turns on immediately strike F8 key continuously, in advance menu option or advance boot option use the arrow key to highlight safemode w/ netwokring and hit enter ( if you see you operating system just hit enter again )
or try this one:
for windows XP,
click start
click run, type in msconfig
in msconfig click the tab for Boot.ini click safeboot at the bottom and choose network, hit enter
click apply and ok
for windows vista and windows 7
click start button or the pearl
type in msconfig in the start search and hit enter
click the Boot tab
click the safeboot and choose networking
click apply and ok
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Siemens Computers & Internet
USB ports not working, slow computer
The error you are getting is the USB port driver. I suggest disconnecting ALL of the items you have connected to ALL of the USB ports and rebooting. If the computer reboots normally, go back and install ONE and ONLY one USB device. Restart your machine. If it boots OK, shut down, remove that device and connect another one, restart again. Do this for EACH of the USB devices until you find one that causes the computer to boot slowly and/or generates the error message. That one is the culprit and needs to be repaired before reattaching to your system.
If, however, after removing all of the USB devices initially and rebooting, you still get the error message, then you have a USB driver problem. You will need to remove the USB driver and reinstall from a known good location (like HP's website) to fix the driver problem.
Jan 07, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
Windows 2k Pro crash with HP J5780 printer and M50 Thinkcenter
Assuming you have SP 3 on 2000, it's possible the USB ports are bad.  Try a different USB device ie mouse, flash drive etc to verify whether the USB port is bad.  If this is the case, you can either purchase a USB 2.0 card and install it on your PC or run without USB ports.
Sep 01, 2009 | IBM ThinkCenter M50 (8189A1UJ) PC Desktop
Dpfmate program will not run
try restarting u computer. or try going into ur recovery menue by presing select and prsing restart and holding the R button when it boots up again it usb mode see if u can access it like that. (dDONT MESS WITH ANYTHING IN THE RECOVERY MENUE JUST USE THE USB MODE ON IT)
Jun 23, 2009 | Bandai Digital Entertainment NARUTO -...
Window XP Media Center Edition won't boot up if Brother MFC-440CN is connected.
I would go first with Brother's support suggestion. You can always go back to the original BIOS setting.
Jul 27, 2007 | Brother MultiFunction Center MFC-440CN...
HP Laserjet M2727nf Multifunction Printer Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
