Question about Music
Silverton radiators branches
Can you solder a grand max Daihatsu radiator
Service schematic for Thomas silvertone Organ 4797
Request the schematic diagram directly from Thomas.
Jul 01, 2017 | Silvertone Music
The input cable fits into the guitar but it won't stay put, it just slides out as if it were too small.
Pro's loop the cable through their belt or guitar strap to avoid cable pulling out or twisting and wearing the connector.
Aug 02, 2011 | Silvertone Revolver - SS11 Electric Guitar...
I have a dean markley promag grand acoustic pick-up which connects to a plug in stap button. when i plug in there is no sound unless the volume is turned up on the amp to the max and then a very faint...
The output of this is fairly low. Do make sure you have steel strings rather than bronze for magnetic pickups like this. Make sure this pickup is oriented per the instructions.
Jul 02, 2011 | Dean Markley ProMag Grand Guitar Pickup
I get a humming sound when I plug my Gibson SG straight nto the amp. The noise fades and strengthens depending the positioning of the guitar in relation to the amp.
Your Gibson is sensitive to magnetic fields You need to keep the guitar about 10 feet away from the amp as the power transformer is radiating magnetic fields that is causing the hum. Solutions: there aree several... most are NOT practical... such as encasing the transformer of the amp in Mu-Metal shielding. Changing the transformer to a toroid type (they should deliver them that way) encase the amp in a thick steel cabinet... all this is ridiculous... putting distance between teh amp and the guitar is probably the only practical solution. The level given any particular orientation should fall off with the square of the distance. Note that OTHER stage equipment also will have transformers that radiate. Much of the new amps do NOT have power transformers that run at low frequency so they don't have this problem. Marshal is old school and they use the older power supply designs that radiate the magnetics.
Apr 16, 2011 | Marshall Amplification Marshall MG15FXMS...
Fuse - 2amp for a Silvertone 1472 Amplifier
Hello endaya try www.digikey.com if you are using a 2amp buss fuse, its available, 117V is applicable to 220V, just follow the amp rating.
Apr 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I want to see how much my guitar is worth its a silvertone. model number 319 14559
Try this l;ink:http://www.jedistar.com/jedistar_vintage_guitar_dating_h2.htm
Apr 01, 2010 | Music
I need a vibrato bridge for a silvertone 1480
Try this website:http://www.rareguitarparts.com/ Hope this helps.
Mar 28, 2010 | Ibanez AF75TDGIV AF Series Electric Guitar...
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
