Question about HP LaserJet CM1312 All-In-One Printer
My MF2727 is constantly re-booting, but only when it is connected to my computer. The connection is with USB. I have applied the June 2011 firmware upgrade to the MF2727, but it has not helped. My computer is running W7 (32bit), and I have installed the March 2010 Full Solution software, 5.2 AM-EMEA1. When the USB cord is not connected to the computer, the printer can be on for the whole day and never re-boot. When the USB cord is connected, then regardless of what I am doing on the computer (working or the machine is actually idle), there is irregular re-booting of the MF2727, sometimes as frequently as 7 minutes, sometimes as infrequently as every hour. Any suggestion other than re-installing the software? thanks,
SOURCE: My computer (PowerMac G4) doesn't communicate with my printer
Get an add-in USB PCI card.  My peripherals work on my G4.  These PCI cards will have 2.0 speed.
Posted on Nov 20, 2007
gewiz
  • 1263 Answers
SOURCE: Unable to install HP F380 drivers on Vista
well first of all uninstall the driver or drivers by going to the Control Panel, programs etc, if there driver is installed . Reboot, Now can you try another usb lead ? http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=&cc=us&lang=&product=1128296 now look at the post called Critical Update to Correct a PC to Printer Communication Issue download the HP Full Feature Software and Drivers install and connect the printer when prompt. Regards GeWiz
Posted on Jun 15, 2009
SOURCE: HP Color Laser Jet printer CM1312nfi: scanner no
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Posted on Oct 17, 2010
puertobori
  • 7733 Answers
SOURCE: HP Deskjet F4480 will not
Windows 7 comes with basic driver built into the operating system (in-OS driver). With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. However, using the workaround procedures in this document, you can still print from a software program. You can also import and view images on a memory card, if your product has a memory card slot. When you connect the product to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Follow these steps to install the basic driver in Windows 7.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the product and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use the following workaround procedures instead.
For more options go to LINK .
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
SOURCE: After firmware upgrade the HP 4015x will not boot
I had the same problem. HP Pro Support advised me to
deinstall the additional paper tray and the toner.
and reapply the firmware update 3 times.
It sounded stupid to me but it worked!!!
Be sure to use usb connection and wait 30 min between progress.
1 st time - no paper tray, toner, wait 30 minutes
2 nd time - no paper tray, wait 30 minutes,
3 rd time - all together now, wait 30 minutes
I hope this will help you and others,
Arthur
Posted on Nov 30, 2010
How to resolve constant boot loop in samsung galaxy fame
use usb connection from your phone and your computer to upgrade your phone's operation system from the samsung website
Jan 26, 2016 | Samsung Cell Phones
Tip
HP CM 2320 "Ready 2 download" is displayed on screen
This error is usually the result of an interrupted firmware update or a corrupt firmware. the following steps may or may not cure the problem. In some cases you will need to have the formatter replaced but these steps are a good step to try before you spend money on parts.<br /> <br /> <ol> <li> <p>Close the firmware update tool on the computer if it is still active on the screen, and then turn off the product.<br /> <li> <p>If the product is on a network, connect a USB cable (2 meters or less) from the product to an open port on the computer. HP recommends that this be a direct connection instead of through a hub.<br /> <li> <p>Turn on the product, and then wait for the message <span>ready 2 Download</span> to appear.<br /> <li> <p>On the computer, cancel any alerts about a new device being connected.<br /> <li> <p>On the computer, open the <span>Printers and Faxes</span> control panel.<br /> <li> <p>Right-click the printer driver for the product model that is being updated, and then click <span>Properties</span> .<br /> <li> <p>In the Properties dialog box, click the Ports</b> tab.<br /> <li> <p>Note the name of the port that the product is currently connected to for use later when reconnecting at the end of this process.<br /> <li> <p>Click the check box next to USB001</b> . If USB001 is already connected to another USB device, click USBXXX</b> where "XXX" is the highest-numbered USB device that has a description of Virtual printer port for USB</b> . Using the scroll bars on the right side of the window might be necessary, depending on the number of devices installed.<br /> <li> <p>Click <span>OK</span> to accept the change and apply the settings.<br /> <li> <p>Restart the firmware update tool on the computer, and then select the same product that was just created.<br /> <li> <p>Start the firmware download.<br /> <li> <p>Verify that the control panel display shows <span>Erasing</span> and then <span>Programming</span> , indicating that the update process has begun. Do not interrupt the firmware update process.<br /> <li> <p>The product should momentarily show the message <span>Complete</span> . Turn the product off and then back on. The product will not automatically reboot.<br /> <li> <p>When the product reboots, on the computer, cancel any alerts about a new device being connected.<br /> <li> <p>Print a configuration page to verify that the update occurred.<br /> <li> <p>Return to the Printers and Faxes dialog box, right-click the printer driver for the product model that is being updated, and then click <span>Properties</span> .<br /> <li> <p>In the Properties dialog box, click the Ports</b> tab.<br /> <li> <p>Click the check box next to the previous port to which the product was connected before the update began.<br /> <li> <p>Click <span>OK</span> to accept the change and apply the settings.<br /> <li> <p>If the product was previously connected via USB, the process is complete. If the product was network-connected, disconnect the USB cable, and then reconnect the product to the network cable.<br /></li></ol>
on Apr 20, 2011 | Office Equipment & Supplies
Tip
Nokia N900 Firmware Update
Nokia N900 Smartphone Firmware Update v3.2010.02-8 (PR 1.1.1)
If your Nokia N900 smartphone is freezing, hanging or acting up I recommend you update the system software / firmware of your device. Erratic behavior can often be corrected by a firmware upgrade.
Here are the instructions for updating your N900 smartphone:
Over the Air (OTA) Update
  1. From the phone's home screen key in *#0000# or go to Device manager
  2. Select Options then Check for updates
  3. Follow the prompts on the screen to complete the update
Update via a Windows PC
  1. Download and install the Nokia Software Updater
  2. Connect your N900 to your PC with the supplied USB Cable
  3. Open the Nokia Software Updater application
  4. Follow the on-screen prompts to update your device
Update via a Mac
  1. Download the 770Flasher tool
  2. Download the latest available N900 firmware image
  3. Turn the N900 off
  4. Connect the N900 to your computer via USB cable (with the device turned off)
  5. Run the 770Flasher application
  6. Drag the firmware you downloaded in step 2 to the 770Flasher application (you will get an error regarding a USB device not being found, ignore it)
  7. Turn the phone on
  8. The update process will now begin automatically once the N900 boots
  9. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
Update via a Linux PC
  1. Download and extract the Linux Flasher tool
  4. Connect the phone to your computer via USB cable (with the device turned off)
  5. Open a Terminal window and run 'sudo ./flasher-3.5 -F -f -R' (you will get an error regarding a USB device not being found, ignore it)
  6. Turn the phone on
  7. The update process will now begin automatically once the N900 boots
  8. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
I hope that helps.
on Apr 02, 2010 | Nokia N900 Smartphone
Restore
These HPs typically have a partition permitting restoration to a condition of the factory defaults via F10 on rebooting the computer. I would certainly have tried system restore before any destruction return to factory defaults. If you can boot the computer from a USB stick (changing the boot sequence via F1 setup), and have it load in a Linux OS, you can recover some of your data files. PC User June 2011 offered such on its disc. Doubtlessly, an update of the technique is elsewhere available. You will want to update service packs after a restore, very likely.
Sep 09, 2011 | AMD Hewlett Packard Pavilion m8000n PC...
WE HAVE A READY 2 DOWNLOAD MESSAGE ON OUR SCREEN AND WE CANNOT GET RID OF IT. WE TRIED SHUTTING IT OFF .
This is the current solution posted by HP. Sounds like your firmware is corrupt and these are the steps you need to take. This may or may not work.
  1. Close the firmware update tool on the computer if it is still active on the screen, and then turn off the product.
  2. If the product is on a network, connect a USB cable (2 meters or less) from the product to an open port on the computer. HP recommends that this be a direct connection instead of through a hub.
  3. Turn on the product, and then wait for the message ready 2 Download to appear.
  4. On the computer, cancel any alerts about a new device being connected.
  5. On the computer, open the Printers and Faxes control panel.
  6. Right-click the printer driver for the product model that is being updated, and then click Properties .
  7. In the Properties dialog box, click the Ports tab.
  8. Note the name of the port that the product is currently connected to for use later when reconnecting at the end of this process.
  9. Click the check box next to USB001 . If USB001 is already connected to another USB device, click USBXXX where "XXX" is the highest-numbered USB device that has a description of Virtual printer port for USB . Using the scroll bars on the right side of the window might be necessary, depending on the number of devices installed.
  10. Click OK to accept the change and apply the settings.
  11. Restart the firmware update tool on the computer, and then select the same product that was just created.
  12. Start the firmware download.
  13. Verify that the control panel display shows Erasing and then Programming , indicating that the update process has begun. Do not interrupt the firmware update process.
  14. The product should momentarily show the message Complete . Turn the product off and then back on. The product will not automatically reboot.
  15. When the product reboots, on the computer, cancel any alerts about a new device being connected.
  16. Print a configuration page to verify that the update occurred.
  17. Return to the Printers and Faxes dialog box, right-click the printer driver for the product model that is being updated, and then click Properties .
  18. In the Properties dialog box, click the Ports tab.
  19. Click the check box next to the previous port to which the product was connected before the update began.
  20. Click OK to accept the change and apply the settings.
  21. If the product was previously connected via USB, the process is complete. If the product was network-connected, disconnect the USB cable, and then reconnect the product to the network cable.
Apr 19, 2011 | HP Laserjet CM2320nf All-In-One Color...
I have Boot error on my NWD-B103 sony walkman
The only way to fix a boot error message on an mp3 player is to do a firmware upgrade. If the firmware is available you will find it on the manufacture's website. It's important that your computer still recognize the player when it's connected because the firmware will be have to be downloaded onto the player.
The firmware should be installed then connect your usb player. Follow the steps given on the web. By the way it will be better if you format your player as well during this installation.
I'm using the same model as you and I'm very glad to share you this.. hope you will try!
Mar 14, 2011 | Sony NWZ-B103FBLK MP3 Player
Zune USB problem. Connects/Disconnect constantly.
Well the microsoft Guys said that when it appears not to work as expected then you need to reset it. Here is the way to do this. Good Luck!
Sep 19, 2009 | Microsoft Zune JS8-00001 Digital Media...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
It wount boot
Get a firmware upgrade to resolve the issue of constant freezing - the DB has become corrupt. If there is no firmware available from the manufacturers' website, then reformat the player.
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 22, 2008 | Audio Players & Recorders
Worked first then boot error now comp wont pick it up
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Jan 31, 2008 | RCA OPAL M4001 MP3 Player
HP LaserJet CM1312 All-In-One Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
