Question about KitchenAid Dishwashers
How to install propeller - KitchenAid Dishwashers
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
Switch off the power supply
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
After Isolating your appliance from the main switchboard,
Turn of the water mains if easy.
Have the new part ready to install and make sure its the right one for the job.
Have a good supply of tools at the ready, at least have a good screwdriver set, an adjustable spanner, a monkey wrench or vice grips. (you might not need these)
Begin by loosening the screw/bolt holding the wash-arm in place, there may be a cap on it, its in the center of the propeller/wash-arm.
Remove the bolt/screw and the wash-arm should come off, it may need some encouragement as they are often pressed on tight.
I hope this Helps a bit...
DO NOT attempt to dismantle the Dishwasher any further yourself unless you are a registered electrician or a qualified serviceman.
If its still under warranty call the manufacturer or the store it was purchased from, they can arrange a serviceman for you.
Good luck and Take Care
Posted on Feb 07, 2014
Just put handle on windtunnel u6401-9rm and the self propelled switch will not flip into self propel mode. is there an adjustment on the self propel part?
When installing the handle on this machine, you must be sure the on/off switch and the self propel button are both in the OFF position. The actual switch inside must also be OFF, and the metal fitting on the end of the power drive cable should be between the two lines molded into the plastic. After it is re-assembled, it is sometimes necessary to wiggle the handle up and down a bit to engage or disengage the drive button.
Mar 16, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Not sure how to remove a driveshaft from a 91 ext. cab mazda truck B2600
Welcome to FIxYa.com
REMOVAL AND INSTALLATION
Remove in the order shown in the figure. Install in the reverse order of removal.
I Image
1. Nut
2. Lock washer
3. Bolt
4. Nut
5. Nut
6. Lock washer
7. Bolt
8. Nut
9. Washer
lo. Nut
11. Lock washer
12. Bolt
13. Rear propeller shaft
Propeller shaft (4x2)
Before removing the propeller shaft, mark the flanges for correct installation.
Propeller shaft (4x4)
Before removing the propeller shaft mark on the front, and rear side flanges for correct
installation.
(4x2 Model)
When the propeller shaft is removed from the extension housing, immediately install the
SST into the extension housing to prevent oil leakage
B2200: 490259440
B2600i: 49 5120 440
1m a
Propeller shaft
1. Align the marks. And install the rear propeller shaft.
Tightening torque: 49-59 N.m (5.0-6.0 m-kg, 36-43 ft-lb)
2. Install the center bearing support assembly.
Tightening torque: 36-53 N.m 3.7-5.4 m-kg, 27-39 ft-lb)
3. Align the marks, and install the front propeller shaft.
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 05, 2010 | 1988 Mazda B2600 Cab Plus
Windows 7 will not see my propel a767. worke fine
Undoubtably. I don't think you are going to have much joy Win 7 doesn't play well with the USB layer, and old drivers... You could try, installing in Admin mode,set compatability for XP SP2, & run all/any .exe as Admin too.
Feb 13, 2010 | Samsung Propel A767 Cell Phone
Ex40-2 slow on one track motor,may be loosing digging power when working hard,have change hydraulic filter and track motors oil
I am assuming this is a Hitachi EX40-2 mini-excavator. Two tests that need to be run. First is the propel motor pressure equal to both propels? Secondly, but possibly more important is to check the slow propel motor for excessive case drain. This would indicate the propel motor is worn out. Find in your hitachi service manual the accepted amount of case drain for that model, disconnect the case drain line from the propel motor and cap the line. Install another hose to the case drain port with the other end in a 5 gallon bucket. Start machine and run propel for 30 seconds. Shut off and check amount of oil in bucket as compared to acceptable amount of leakage from machine spec book. All this does is measure the amount of leakage past the propel motor slippers, which gives an indication of excessive wear tolerances. Replace propel motor if needed.
Jan 04, 2010 | Garden
How to install the belt on the hoover self propelled vac
Video Repair instructions on installation of Hoover Windtunnel Self-Propelled vacuum ;
If you found the video helpful, please be sure to rate it by clicking the thumbs up icon below. If you have any questions about this repair, please request a clarification below.
Thank you,
Chris
Jul 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
How do we replace propeller on super cub?
The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
Jun 14, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
Self propel belt is too tight to put back on
the best way to install it is to put it on the motor shaft first and then to start putting it on the large pulley at the top and roll it on these belts can be hard to put on.
Jan 05, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Generic problem for all Vacuums
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
Dishwashers Logo
37 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
