Question about Radio Communications
Midland nt1 antenna - Radio Communications
I have a midland 2 way radio trying to transmit and receive without static
If a handheld radios check your battery and/or antenna. Trade with a known good unit to see if the problem is solved with either. A poor battery can often cause static.
If a mobile radio, check your antenna connections and your antenna and coil. This could be a sign of a poor antenna or antenna set-up.
Best regards.
May 15, 2015 | Midland Radio Communications
Does a midland cb 40 ch have a range for distance?
  • Hi, I can help.
  • In general a CB goes roughly 1 mile per watt of power. A Midland CB out of the box will get you about 5 miles. After a Peak and Tune, a Midland CB can get out around 25 miles. If you put an SWR/Watt meter inline you can tell how much your rig is putting out.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
regards, Tony
Sep 01, 2011 | Midland Radio Communications
I bought an older midland 2 way radio used for logging in Prince George British Columbia..hooked it up in my truck but there is no reception over the speaker...any suggestions
heck your antenna for problems. Wire could be broken, shorted or other problems. If the antenna is shorted this may be normal in some cases as some antennas are designed to be DC shorted.
Jul 11, 2011 | Midland 79-290 120-Channels Base CB Radio
Last year I got this device and after 1 & half year my device is not working & showing check gps antenna. Can u please give me a solution Javaid
Probably the gps antenna is not working due to rusty (water inside it). Check the antenna disassembling it. Third part antenna for the NT1 is not available due to proprietary connector so you must buy a (expensive) genuine new one from JVC. Sometimes it's possible repair the old one.
Apr 21, 2011 | JVC KW-NT1 Car GPS Receiver
MIdland no sound s/rf dancing
may be u burned yr final transistors...check if yr antenna is well grounded and try just after this to transmit, if the indicator is not stable on the green area when you are in "am" modulation stop to try and bring to the assistance
rgds Stefano
Dec 17, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland handheld CB antenna
The connector that's part of the radio, or part of the antenna broke?
Oct 30, 2007 | Radio Communications
"squeak" when transmitting
Make sure you have a good ground for the radio and antenna. How long is the antenna coax if a little to long and you have extra what did you do with it coil it if so uncoil it and lay it out try it. If no luck I would shorten the coax and recheck your SWR.
Jun 22, 2007 | Midland 1001Z 40-Channels Base CB Radio
Radio Communications Logo
26 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
