Question about Yamaha Audio Players & Recorders
Sirius antenna error
When trying to listen to XM radio, get a message that says "check antenna" and it doesn't work.
  • 20 Answers
SOURCE: Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Posted on Apr 27, 2008
  • 43 Answers
SOURCE: XM Radio online use problem
Yeah use sirius radio service. Prolly a reason that it isn't running it anymore because Xm and Sirius merged company's. So Sirius is the same as Xm now.
Posted on Jan 09, 2009
TOLhamRadio
  • 509 Answers
SOURCE: Yamaha RX-V757: Tuner not working
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Posted on Jan 12, 2010
  • 150 Answers
SOURCE: xm radio
Try with a different XM Antenna from a friend or shop if possible to verify whether it's the antenna or the unit itself.
Visually inspect antenna cable and connection at the antenna and the unit and make sure the antenna cable hasn't been damaged.
I would do this before considering other options
Good Luck!
Posted on Jan 17, 2010
  • 175 Answers
SOURCE: How do i hock up to XM/SIRIUS Radio ?
is this service available in ure area
Posted on Apr 27, 2010
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Jul 17, 2014 | Audio Players & Recorders
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
How do I display the radio ID number, so that I can listen to Satellite radio?
Verify if the radio is "Satellite ready" or if it comes with the remote tuner unit. I believe you have to buy a separate tuner add-on and antenna in order to activate the satellite circuitry - THEN it will show you a radio ID. I think ONLY the Alpine comes with the tuner. I would call Crutchfield and they can tell you what all you need with that tuner to make it work with the satellite radio.
Jan 14, 2012 | Panasonic CQ-DF783U CD Player
My sirius portable radio keeps displaying "no antenna detected" but it's plugged in.
Several possiblities: one: antenna really is bad - borrow a friends Sirius or XM antenna and plug it into the base and see if the message goes away -if it does, replace antenna; if not, then your 'dock' or base could be bad - try removing and reinstalling the radio or try another base. If another base and antenna don't solve it, then the radio is shot and it's time for a new one. Customer service will ususally give you a great deal on a new XM radio IF you agree to keep it for 1 year. Let me know how it goes.
Jan 12, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Jan 12, 2010 | Yamaha RX-V757 Receiver
Jan 09, 2009 | Audio Players & Recorders
Apr 08, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
SIRUIUS SPORTSTER
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Feb 25, 2007 | Sirius Satellite Radio Sirius Sportster...
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
