Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
How do I remove soot from my walls caused by baseboard heat
5 Suggested Answers
  • 10 Answers
SOURCE: oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Posted on Mar 16, 2009
  • 252 Answers
SOURCE: There is black soot on my walls and ceilings above
In my experience soot in the house is (almost) always caused by the burning of candles. Get a CO detector if you don't already have one! You see the soot at the heaters because of the air flow they cause. There is nothing in a baseboard unit that could cause soot. Just water.
Posted on Mar 30, 2009
SOURCE: I have black soot on
same issue years ago. these heaters draw air in from the bottom and push it out the top. so any dirty air (candles burning will do it) is pulled through the heater and pushed out the top causing stains on walls.
Posted on Sep 18, 2009
  • 3 Answers
SOURCE: there is a black "soot" coming from my radiant heater
Black soot appearing above and around electric baseboard heaters is caused by burnt hydrocarbons in the air.
The Heating element draws the cool room air from the bottom and over the element. Any excess hydrocarbons in the air become burned and are deposited on the surrounding surfaces from the warm heated air flowing up out of the heater.
The Heater is not the cause of these hydrocarbons. They come from the home / enviornment.
Some cause.
Smoking, burning Candles releases waxy hydrocarbons, carpet cleaning solutions, spray type air fresheners.
Black waxy sooty deposits are usually from burning candles.
Posted by George Patterson
Posted on Oct 07, 2009
Our Rinnai gasheater is in 'n working condition but since we used it the white walls and ceilings are covered with black marks - I am worried that it could be dangerous - any advice?
Unfortunately, you failed to mention the Model Number and whether its a flue-less or Vented unit. In either case, the black streaks you see on the walls and ceilings is soot. If it's a flue-less unit, this is an indication that the unit has not received routine maintenance on a regular basis. The sooting is caused by a dirty or clogged burner or low gas pressure.
Also, burning scented candles and operating the heater at the same time, will cause soot. Not from the heater, but from the candles. All candles soot, but scented candles soot more than others. Combine them with the warm moist heat and they will soot 50 times worse. If this is the case, it's the candles sooting, not the heater. Stop burning the candles while the heater is in operation.
Is the soot dangerous? Yes, to the point that you are breathing it in, when it;s floating in the air. The sooting didn't occur over night, it has been doing it for sometime. You finally realized it, when you saw the black streaks. Stop using the heater until it is professionally serviced by and authorized Rinnai Service Technician and the walls and ceiling are cleaned.
You can either remove the soot yourself or have it professionally done. Then, you should prime paint the walls and ceiling with a sealer like Kilz, before repainting. All curtains or draperies should be washed or dry cleaned. All furniture and carpeting should be vacuumed thoroughly.
I hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | Heating & Cooling
Black soot is on the walls & ceiling around the baseboard heaters in the rental house that I live in. What is causing this & how do I clean this off?
If these are electric base board heaters, that is probably not soot, but instead mold. Put a little bleach in a spray bottle and try spraying it right on to the black soot looking stuff and see if it will disappear. If it does, it is mold. Bleach will kill the mold.
If these are gas heaters you need to call a service man NOW. Black soot is a sign of gas burning raw and can be very dangerous. Turn them off if this is the case.
May 18, 2011 | Heating & Cooling
Above some of the baseboard electric heating vents (the whole house is wired with electric (not gas, oil, or coal) heat there are black marks on the walls. what is causing this??? I do not burn candles,...
While it could be nothing, it is a good idea to have a heating professional check them once in a while. Sounds a little odd, though, as most electric baseboard heaters have no vents. You will be comforted by the reassurance of having them looked at. Farmerbear at FixYa.com
Sep 28, 2010 | Fahrenheat Built-In Baseboard Thermostat...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
There is black soot on my walls and ceilings above my baseboard heaters. Is there a solution or a reason as to why this is happening? Is there a part that needs replacing? We are desperate for a solution....
Mar 30, 2009 | Fahrenheat Electric Convector Baseboard...
Oil baseboard heat v electric baseboard heat.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
There is a black "soot" coming from my radiant heater
Some cause.
Jan 13, 2009 | Fahrenheat FBE15002 Baseboard Heater
I have black soot on my walls from my baseboard heaters, is this hazardous or dangerous to my health?
Jan 01, 2009 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
