Question about Vizio Gallevia GV42LF 42 in. LCD Television
2" Vertical Lines down the middle of my tv? - Vizio Gallevia GV42LF 42 in. LCD Television
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
Black vertical lines on samsung lcd tv.when powered on the black vertical line appears in the middle
Vertical lines are usually a a sign that your T-con board is going bad. You can get replacement parts for this TV at www.interliquidparts.com
Sep 27, 2011 | Samsung LN32A330 32 in. LCD TV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I get vertical lines running down the middle of paper
lift the lid ull see a thin **** glass make sure its very very clean
Mar 30, 2010 | Sharp AL 1631 Copier
Vertical lines on LCD tv monitor
this is an address registry problem a technician needs to cure this issue.
Jul 10, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Vizio Gallevia GV42LF 42 in. LCD Television Logo
15 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
