Question about Honda 3000 Watt Portable Generator
Eb3000c honda generator governor
Setting throttle governor
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: i have a pramac generator
I will respond agan in less than 1 hour with what I can without your Pramac generator model number. I need the model number of the generator to get you the correct answer. In the mean time I will search for what I can find without it and respond ASAP. Expect an answer in less than 1 hour.
Kelly
Posted on Aug 20, 2011
My model 1431 diesel engine can not reach full rpms .and under a load starts dieing until the engine load is released.then trys to rebuild rpms.why.I already replaced the fuel filter.
the operation of a governor system in all pumps is to remain at full throttle until the governor control reaches a predetermined setting
so it is at full throttle when stopped , starts and the governor setting is idle so it runs at idle until you change that setting in which case it moves back towards full throttle again
I explain it like this so that it can be understood that from your description you will see that there is a problem in the governor control system
As governor control is critical in a diesel engine I suggest that you seek a proper diagnosis from an accredited professional diesel pump repair shop as it is very possible that the pump or electronic control will have to be inspected / repaired
Mar 25, 2017 | Cars & Trucks
Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Sep 23, 2008 | Garden
How to set goveners
As a rule there is a rod that runs from the governor arm to the carb throttle plate arm, sometimes there is a lot of holes to choose from to put that rod into. For most mowing type settings you push the throttle wide open on the carb and push the governor arm all the way full throttle and connect the rod by using whatever hole will let you or bend the rod to get into a hole. Your throttle cable will be connected to the governor arm with a spring ,this will allow the governor arm to swing back and forth to hold a steady RPM that you selected with your throtle cable. In a non mowing application like generators, the voltage output is regulated by the RPM so it would be adjusted by using a voltmeter and setting the governor to get 120 volts 60 cycle at the plug in, In the USA. Without the make and model it is hard to do more then talk theory but if you're handy this info will help.
Apr 07, 2016 | Garden
Governor reset
Are you asking how to reset governor linkage to factory spec? If so, move governor arm in direction that opens throttle valve on carb wide open. Hold in this position. Loosen small nut on bottom of governor arm. With a needle nose pliers turn center arm that goes into engine in the same direction you turned governor arm to open throttle valve. Holding in position, now tighten nut on governor arm tight again. This is referred to as a static setting and is factory spec. Good luck!
Sep 21, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
I have a craftsman tecumseh 4.5 hp mower throttle free type and i have cleaned and rebuilt the carb replaced the carb mounting gasket between the carb and intake and also replaced the o rings on the...
1ec7ba32-45ac-4b07-8389-f863014e42da.jpgIt still sounds like a carburation issue. Are you sure all jets, vents and ports in carb are open? Another possibility is that the governor setting is off. The governor is the rod that comes out of side of engine and connects to throttle linkage on carb. To set governor to factory setting, push governor linkage in direction that opens throttle valve, loosen screw on governor arm and turn rod in same direction until it stops, while holding in this position tighten screw on governor arm. This is called a static setting. If this doesn't work I would disassemble carb, remove all plastic and rubber parts and soak in carb dip overnight. Picture may be different from your unit but it shows governor linkage to carb. Good luck and happy wrenching!
Sep 18, 2013 | Garden
I have a briggs model 407777 that was idling up and down from near top range to bottom. Found some dust in the carb intake and decided to cliean the carb. When removing the manifold/ carb, I took loose...
These can be tricky, but your on the right track. With throttle set on high (engine off), turn governor linkage in the same direction that opens throttle valve in carb wide open, then turn the governor rod in that same direction then tighten bolt on governor arm. This is a static setting. The high and low idle is most likely a dirty carb so assuming the carb is now clean your idle should be better. Hope this helps. Good luck!
Aug 12, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lt 166 govenor adjustments how to
Your governor should not need adjusting unless someone moved it and you want to go back to factory setting. Having said that. You will loosen small nut on bottom of governor, follow the travel of governor to watch the throttle in wide open position. Hold it in that position then with needle nose grip the center of stud coming out of bottom center of governor and move this all the way in same direction as wide open throttle, then snug it up and your done. Good luck.
Jul 22, 2013 | Garden
Honda gx160
Kescorpio56:
Check your throttle and choke settings. Something is causing the throttle plate in the carburetor to remain open or the governor is improperly set. I would reset the air/fuel mixture screws to one and a quarter turns out and back the idle screw all the way out. Make sure that the throttle cable operates the throttle properly and check the governor setting and reset the governor setting if needed. Start the engine and adjust from there. When the engine starts, adjust the idle screw until the engine idles. Adjust the fuel/air mixture screws for the best idle. Then run the RPM up and adjust the fuel/air mixture screws for the best run/idle combination. Don't forget to adjust the governor if the engine runs too fast or too slowly.
May 31, 2013 | Air Tools & Compressors
How to adjest the carb on a honda hrr216 self propell mower
Ron:
If the mower starts easily and runs well but surges, the problem is not your carburetor! There is an arm coming from the crank case that links to the carburetor throttle arm with a small rod (the rod has a spring around it). That is your throttle governor. Loosen the nut where the governor arm meets the shaft going into the crank case, set the throttle to full throttle and using a pliers, twist the governor arm (coming out of the crank case to full open (twisting the shaft in the same direction that the governor arm would twist it when you go to full throttle). Tighten the governor arm nut without changing that setting... don't let the governor arm move or let the governor arm shaft (coming out of the crank case ) move or the setting will be wrong. ( I know... a third hand would be useful to hold the governor arm to keep it from moving). You may have to make that adjustment a few time to get it right.
Mar 22, 2013 | Garden
Setting the govener
You should not be messing with the governor. The governor wants to slow the engine down. See which direction the throttle shaft needs to travel in, usually from the carb to the governor, to close the throttle butterfly, NOT the choke plate. Loosen the governor clamp, rotate the shaft clockwise while holding the governor in the same direction. Use your head to determine how to make these things happen while tightening the governor nut back up. The engine shouldn't race, and the throttle cable should now work. I shouldn't have told you any of that. Ok, here; if your motor blows up because you do something wrong, I TOLD you not to mess with the governor BEFORE I explained how to adjust one. But that's how you adjust one.
Jun 09, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Honda 3000 Watt  Portable Generator Logo
96 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
