Question about Gateway NE56R47u Notebook
File:\windows\sysytem32\winload.ef: error code 0xc0000001
How do I correct the problem code C 0000001 on Windows 8 operating system
Solve Error Code 0xc0000001 in Winodws 8 Team Windows 8
Windows 8 Blue Screen of Death (BSOD) or Error Code: 0xc0000001 sometime occurs without any specific issue. You can't be sure what actually caused it. Be it a system issue or some driver problem, you may end up seeing this screen when you restart your computer.
To solve this blue screen error in windows 8, turn off your computer and when you power it up again, immediately press SHIFT + F8 key you will be resented with following screen:
Click on "See advanced repair options" and from the next screen, choose "Troubleshoot":
On the next screen, choose "Advanced Options"
In Advanced Options, choose "Windows Startup Settings"
There you will find a button "Restart". Click on this button and allow the wizard to complete all the steps. Note that it will repair your computer without making any changes to it. Once the process is completed, your computer will automatically restart and you should be able to boot windows now.
Still facing same error?
If you have followed all the above mentioned steps but got no luck in booting up your windows then probably your cause of the error is more solid and cannot be restored with mere settings reset. But don't worry, it can still be solved using windows recovery options. For this you should have a recovery/installation disc or USB Flash Drive.
Windows 8 Recovery Guide Recover When Windows 8 Fails to Boot Team Windows...
Jul 07, 2015 | Computers & Internet
Undefined
reinstall windows or repair it with installation disk. Or request an iso file from microsoft, burn it, and boot it
Oct 21, 2014 | Gateway Computers & Internet
My laptop operating system failed to start it has an error code: 0xc0000001
It is probably a hard drive failure and will either require the operating system to be repaired, rebuild or at worst case the hard drive to be replaced and then the operating system to be reinstalled.
It is impossible to go further without expert examination so I advise you to find a reputable repair man.
Aug 21, 2014 | HP Computers & Internet
\windows\system32\winload.exe missing or corrupt 0xc000000f for toshiba
This is usually a fatal error.
The hard drive has either a damaged sector or the windows file is damaged/missing. Try pressing F8 just before it tries to boot and select repair or restore.
Dec 26, 2013 | Toshiba Satellite Computers & Internet
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
When i start up my computer it goes straight to boot manager and gives an error code file\ windows\ system32 \ winload exe,,, status 0XC000000F file missing or corrupt, what is the issue please, system is...
The problem you have is with the system boot files. There is a corrupt file and that is stopping the system from booting.
Press F8 as the system starts up, that will let you into the special boot menu and hopefully will give you the option of repairing your system. The timing can be quite tricky as there is only a very short time window. Trying a few times should get it.
Hope that helps.
Nov 21, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
New pc core i3 intel orignel mother board DH55TC DDR3 2+2 RAM DVD R/W VIP SMPS PROBLEMI NSTOL WINDOWS 7 &VISTA BOOT CD 1 STEP :- WINDOWS IS LODING FILE STEP :-2 ERROR LODING WINDOWS 1 PLS INSURT CD AND...
Here is a possible fix found at the Microsoft knowledge base .
read and follow the instruction given.
If you are not comfortable with the registry fix then you may have to call the mother board tech support for further instructions but this is found in the Windows 7 environment or operating system.
Article ID: 927392
Apr 01, 2010 | Computers & Internet
I dropped my computer and now I get error An unexpected I/O error
Attempt to Re-Install Windows (most likely this will not work) if it does not then you need a new drive. The insides of the harddrive have shifted
Jan 11, 2009 | Acer TravelMate 5520 Notebook
Erro message
hi it is some problem .exe file. you setup regd recovery
download it download.com
or setup c drive xp boot cd to recovery .exe file.
go to run command type sfc then enter. setup
Feb 17, 2008 | Microsoft Windows XP Professional With...
Gateway NE56R47u Notebook Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
