Question about LG DLE5001W Dryer
I have a LG Dryer Dle5001w that is 3 years old. It no longer will dry clothes on timed or sensor options in a reasonable amount of time. One average load takes 3 hours to finish. It does heat well and the drum does turn. The flow sensor comes on about 20 min into every cycle. I have had 2 repair men come out and tell me the unit "seems fine". The temperature is in normal ranges so heater element is fine. The motor is running fine and has not blockage. I have had the thermastat replaced. I have pulled it away from the wall and ran it without anything to block the air flow. I have taken the back off and vacuumed inside and the vent tube. I have cleaned the sensor bars to make sure there was no build up. Nothing has worked. LG customre support has been not help. Does anyone have any ideas?? Please help!!
    Welcome Back:
    Visited the website for 2 consecutive days.
Have a repair man check to see if the sensor that turns on the heat in timed or sensor mode has a good connection or needs replacing if that doesn't work it may need a new computer
Posted on Feb 07, 2014
4 Suggested Answers
  • 105 Answers
SOURCE: lg dryer not drying
Do not keep it higher temp unless bedsheets are inside.For normal clothes temp must be at normal level.If more steam remains inside then only clothes will remain damp.Look out for correct RPM.This problem comes due to drive belt also. Even it looks tight just replace blindly.Hope this will solve your problem.All the best to you.
Posted on Feb 10, 2007
  • 489 Answers
SOURCE: LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Posted on Apr 28, 2008
  • 574 Answers
SOURCE: LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Posted on Aug 25, 2009
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
We have a LG dryer that is about 2-3 years old. The sensor is completely lit showing an obstruction but we have cleaned the vents out all the way to the roof and the sensor stays fully lit. The clothes...
Check the exhaust vent behind the dryer to make sure it's not kinked.
Take off the dryer vent and run the unit to see if it will dry normally. If it does, you still have a blockage in your exhaust vent in the wall.
Jul 20, 2011 | LG DLE2532W Electric Dryer
The clothes simply won't dry. I know it is producing heat because the clothes are warm and the heating element is hot to the touch, but the air that is coming out the back is not hot at all. I have...
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Hold down on the 'More Time' and 'Less Time' buttons and press the 'Power' button. if it comes up with tE1 or tE2 you have a thermistor error.
LG DRYER MANUAL
Jan 19, 2011 | Dryers
Hello my dryer doesnt work properly it runs
Problem:
Solution:
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
Jun 17, 2010 | LG DLG7188 Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Wet clothes take two 'trips' to dry.
UNPLUG THE DRYER THEN PRESS THE MORE TIME , AND THE LESS TIME BUTTONS AND THE POWER BUTTON FOR ABOUT 10 SECONDS. THEN WAIT FOR 3-5 MINUTES THEN PLUG THE DRYER BACK UP . SEE IF THAT WORKS BY THAT RESET.
Dec 01, 2008 | LG DLE2514 Electric Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
LG DLE5001W Dryer Logo
177 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
