Question about Maytag MEDE200XW Dryer
Dryer lites come on, hold button, will not start
Whirlpool GGW9868klo dryer just will not lite up when I push the normal button the lite comes on when you opin the door so i have power just wont start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Whirlpool GGW9868K Gas Dryer
My duet dryer is led lite stuck in control lock. I did not do it, not sure why it is in this mode. I do not know how yo fix. ( used last night was fine) Terri
Lock mode is enabled pressing the "lock" button for a few seconds. You can unlock it pressing the "Lock" button and hold it for a while.
Nov 24, 2010 | Whirlpool Dryers
Kenmore Elite Dryer will not start. When I press 'start' all button lite up, but the 'start' button give out a low buzzing sound. It will not stop until I press 'cancel'.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 31, 2010 | Dryers
Kenmore elite dryers made 2005 was in a foot of water in a flood. push the start button just clicks. push the start button and hold it down and the drum wont turn on but the ignitor will heat up and lite...
foot of water huh
well any relay switch fuse ect.
the top board should be fine.
is there any rust inside the housing if so the dryer is definitely not safe to use anymore.
check for wires with water in their conections.
Jul 29, 2010 | Kenmore Dryers
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer wont keep spinning without me holding the start button down
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Kenmore 64902 Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
Maytag MEDE200XW Dryer Logo
16 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
