Question about Plumbing
Foul Odor & Occasional Leak
Hello, I have an issue, I believe to be drain related, in my house. We bought the house three years ago and had put laminate in the kitchen knowing it wouldn't last long in there, but I knew we would be doing some updating in the kitchen within a couple of years. Last year, the flooring quickly started to curl up and luckily we were planning to do the kitchen updates soon anyway, so that part worked out ok. I had figured since we had the dogs' water bowl and crate in the area that likely they had been splashing water on the floor and thought maybe an accident or two in the crate caused the floor to go bad so quickly. When I started pulling up the laminate to replace it in February, there was a surprising amount of water under the moisture barrier. I figured it was just water that had collected from the dogs being dogs and didn't think anything else of it and installed the tile and made the other updates we wanted to make in the kitchen. To give you an idea of our set up, the kitchen sink is on the east wall, right before the end where the cabinets make an "L" and continue for about 18" on the south wall and the stove is in the space next to that. Our bathroom is behind the south kitchen wall and the bathroom sink, toilet, and bathtub are all on that wall. One night, during the updating, I was painting the base cabinet frames and my wife decided to go in and take a bath. I was working in the corner mentioned above with the doors and drawers all off. Soon after she finished filling the bath tub, there was a strong, rotten smell. It was so strong and awful, I quit working for the night. (And of course, I gave my wife a hard time that she stunk so bad I couldn't continue working. haha) I had noticed the odor before, but it was very faint and I had thought it was due to the laminate flooring having water damage. Anyway, within a couple weeks the kitchen project was complete and I didn't really notice the odor again.... for a while. Fast forward to this last fall, around late September. We had tone out of town for 10 days. We had someone house sitting for us, so assumably, she had used the sink(s), bathtub, and toilet while she was here....but there was a small stream of water running from the cabinet all the way across the floor... I thought it must have been the cooler we brought in there to unload into the fridge was leaking, and again, didn't think anything of it. A couple weeks later, the stream reappeared, and has infrequently appeared since. I checked the sink drain pipes and water lines, and have not found any leaks. I put a container under the p trap thinking maybe a slow leak along the drain, but there has never been water in the container. Out of the blue, I thought back and remembered all of the stuff above combined and it clicked a few months ago that we must have had some kind of plumbing issue before I ever removed that laminate flooring. The strange things I've noticed since: - It doesn't happen all the time... But I would say up to a few times a week. - It seems to happen more easily before a weather front.. and if it rains, during and shortly after the rain system. - It also seems to be easier to happen in the morning when we both take a shower, use the sink, and toliet... especially if we run the dishwasher. - The leak doesn't always seem to "come" from the same place... sometimes it comes from under the stove, sometimes it seems to be coming from under the cabinet where the sink is, and sometimes it seems to come from under the dishwasher. - The foul odor is pretty much constant if we open the cabinet on that south wall, or the sink cabinet, which is open to to the corner cabinet (house is from the 60's, the cabinets were built in, rather than the individual cabinets of today.) - The odor is also more noticeable within a 10-15 ft radius of the area of concentration now. - There is never any hint of the odor or water leaking in the bathroom. One extra note -- There is a whole in the wall with an panel covering it in the kitchen in the back of the cabinet... while I was working in the kitchen, I took it off and it seemed to basically just be an access point for the plumbing for the shower. that panel wasn't attached to the wall, it just -- for lack of a better word -- leans against the wall.... It falls back off the wall pretty easily and the odor seems to be worse when it has fallen back off the wall. I got up on the roof and peered down the vent pipes with a flashlight the best I could, I didn't see any obstruction there. We also haven't had any issues with slow draining in the sinks or bathtub either. I have noticed tiny little air bubbles in the toilet bowl around the opening, but I think that's normal when it's a so cold in the winter as it is right now. Anyway.... I know its time to call a pro... I'm just scared to death it's going to be a major repair that will be wildly expensive.... I can't think of anything it may be....So I thought maybe someone on here would have an idea. Is there anything else I should check before calling a plumber? Or even if I've exhausted all possibilities to avoid a plumber, what might be going on? This post got way longer than I intended, but I wanted to be as detailed and descriptive as I could... So I apologize for the lengthy explanation..... I do appreciate anyone taking the time to read it though, and ever more grateful for any idea that anyone may be able to offer. Thank you!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Looks like you were suffering thru the same thing we have in our house - did you ever get a solution to this? I was wondering if some of your vent pipes were cracked or partially clogged, especially where you had that plumbing access hole in the wall. Hope you've got this fixed already, since plumbing companies usually charge about $350 to run those smoke tests to find and pinpoint problems, and it doesn't always work. Buzzie
Posted on Sep 10, 2014
frcs68
  • 1605 Answers
SOURCE: Broken pvc plumbing for bathtub faucet.
if you have tiles in the bathroom wall, the answer is yes!
it is better to go fromthe back, where there is drywall.
since PVC is glue on, you have to cut out the pipe and reconnect.
make sure the bathtub faucet is not broken, and can be reuse.
Posted on Nov 11, 2008
  • 336 Answers
SOURCE: Who has the best nipples? ;)
I don't know what the nipples are connected to but you may have a dielectric issue. If the nipples are chrome plated brass and their attached to galvanized fittings you're eventually going to have a problem, because of the mixing of the two metals is causing dielectric corrosion. Even wrapping teflon tape isn't going to help since NPT threads are sharp and will cut through it when you tighten them. Try to get nipples made of the same metal as what they are attaching to. I recently purchased some decent chrome plated brass nipples from Home depot, but they weren't 24" only 8". I hope this helps.
Posted on Aug 19, 2009
  • 255 Answers
SOURCE: Hi, Have a situation. My bath tub(2nd floor) is
You will have to bust out the ceiling where the dripping is occuring to get to the pipes. Before doing so, check and see if your house was built with an access door for the valves. (Look on the other side of the wall where the valves are.) I have the very same problem and am going through ceiling replacement after repairing the pipes. It is a mess. Good luck.
Posted on Nov 30, 2009
  • 126 Answers
SOURCE: installing above counter sink and is leaking on
Sound like you have the wrong drain assy.or its installed wrongsometimes I put pipe dope on the top side of the rubber gasket and around the threads of the pop up and really tighten the nut.
Posted on May 17, 2010
SOURCE: my shower drain was running slow during a shower,
You can try using rock salt and boiling hot water down your drains. That will help if you have roots getting into your line. Chemicals are not very good for your pipes. If you have PVC drains the chemicals can eat a hole in the pipe because most of them have acid in them. They are also bad for your health (breathing in fumes, getting on skin, etc.) If the line is broken down, has a break in it, it will need to be repaired.
Posted on Jan 25, 2011
What does a freon leak in a deep freeze smell like?
Freon is odorless. A sewer odor could be caused by an unused sink, tub, or floor drain trap where the water has evaporated. A gas odor is a very serious issue that should be checked immediately by the gas company or the fire department. Gas can seep in from a leak outside the house or accumulate in a wall if a fitting fails.
Aug 26, 2014 | Kitchen Appliances - Others
My 2003 Mercury Mountaineer has an electrical problem. It started about a year ago with the key fob not working, I have bought 3 and all won't work even after re-programing. now tonight I went to
Could be a windshile leak down the A-Pillar & water
gets into the delayed accy relay for the GEM Module
(Body Computer as ford called it for a few years) & you
get what you have now
Try Goolge as I did a few weeks ago for a relative
He had the same issue with the blower being on &
killing the battery
No real fix I found for the windshield leak
Seem a robot didn't put the rubber sealant
on correctly at the factory fo about 5 years
on several fords.
If it isn't water related then the GEM Module
controls all those body features
If you get a used one & match up the numbers,
you supposedly can avoid buying a reman gem
& the expense of having to reflash it to your factory
built combination
Jan 27, 2013 | 2003 Mercury Mountaineer
We have a 5 year old front load whirlpool duet washer that leaks & floods and has since we bought it. We had it replaced within a year of purchase, but it continues to leak & flood even with a new...
Due to the fact that you have had two different machines with the same problem seems to rule out a problem with the machine itself. Inspect the drain system that the machine discharges into. I have seen washers that have pumps which can overwhelm the house drain--the cure was to increase the machine's drain spout outer diameter with duct tape until it was a tight fit into the house drain. This prevented water overflowing from that point. The better cure would be to increase the drain pipe size, but that can get pretty expensive. Hope this helps!
Nov 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Foul odor on dishes and in dishwasher after cycle
It is very likely that your dishwasher is growing mold, in this condition. If it is causing your dishes the same issue, it may be wisest to obtain a dishwasher cleanser(Several detergent manufacturers now sell dishwasher cleaning items), which will hopefully kill off any mold colonies growing in your dishwasher's blades, and in your drain cap.
Apr 23, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Where is cabin ac filter located
If the air conditioner emits a foul odor into the cabin it is probably the drain tube on the evaporator core is clogged. What happens is the clog causes mildew to start growing and then it blows the stink right into the car. And to answer your question the cabin air filter location all depends on the year make and model of the car.
Jun 09, 2009 | 1999 Ford Windstar
Gasoline Odor
A gasoline leak on or around the engine. Bad mileage lately? Check fuel lines and where parked to see if anygasoline leak.
Dec 18, 2008 | 1997 Chrysler Concorde
XL-15 Classic Living Air emmitting Foul Odor!!
Ionizers do cause a bad odor to happen. I work in the copier business and do work around machines that can cause an ozone to happen when there are ran. Copiers like ionizers can cause an ozone to happen because the air particles are being electrically charged. The smell isn't good to be breathing in as well.
Here is an EPA report about ionizers
The Consumer Products Safety Commission is going to be making a decision about the health effects on ionizers by the end of the year. Their decision can effect selling ionizers all together.
This industry should have been regulated years ago and after what happened to Sharper Image this year due to their arrogance it isn't doing the industry any favors. They went out of business because of Consumer Reports findings and tried to sue them for it.
If you really want the air in your house cleaned, the best way to do it is using a hepa filter.
Jul 26, 2008 | Ecoquest Living Air Classic Air Purifier
Living Air XL-15 Classic - Foul odor!
Hi cant standit,
Can you control this odor by adjusting the ozone (O3) control? High levels of O3 smell obnoxious or irritating to some people; you want a fairly low concentration (~40 ppb - that's parts-per-Billion, not much).
It sounds like you've done everything else right. Have you consulted with the dealer you bought from? How about EcoQuest? If it's not the O3 level being too high, then perhaps there's something goofy with the unit. If it's under warranty, pursue that option. You should have contact infor with the unit; respond if you need it and I can post it.
Let me know.
Jun 06, 2008 | Ecoquest Living Air Classic Air Purifier
Plumbing Logo
297 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
