Question about Dell Vostro 1320 Notebook
Reset battery password bios jumper - Dell Vostro 1320 Notebook
5 Suggested Answers
  • 43 Answers
SOURCE: how to bios reset jumper location dell c400
try to remove the cover of your laptop. Then remove the motherboard battery for about 10 min. Put it again and bios should be restarted.
Posted on Mar 20, 2009
  • 3940 Answers
SOURCE: where is the BIOS Password Clear/Reset jumper
There is no Jumper on a Dell Vostro 1000 to clear the password. You will have to contact Dell Technical Support, Complete a ownership validation to confirm you are an authorized user of the system, then they can provide you with a Master Password to clear the password
800-624-9896 in USA
Posted on Jul 11, 2009
  • 11 Answers
SOURCE: I am failing to remove the Bios password in Dell Latitude D630
This should be pretty easy to do.
1. Reboot your laptop and select F2 to go into the BIOS settings. You'll need to be quick or it will boot to Windows.
2. Use the --> arrow key to move to the Security page.
3. Arrow down to the Set HDD password and press Enter
4. Enter your current password
5. Select the Enter key twice to enter no password
6. Select the F10 key to save and exit.
Posted on Dec 17, 2009
sim4182
  • 393 Answers
SOURCE: how to reset Dell Vostro
hello sir... i can help you..
send me your service tag wich u can see on bottom .. or when you turn on your system you will see a hash code.. like this #1234567-595b send me that one i will send you master password
Thanks
Posted on Nov 21, 2010
How to reset or clear a system bios password
The general categories of solutions to reset a BIOS password are:
  • Using a Backdoor BIOS Password
  • Resetting the BIOS Password using Software
  • Resetting the BIOS Password using Hardware
  • Vendor Specific Solutions for resetting the BIOS Password
  • or with a simple one is taking out the cmos battery then place it back 5-10 minutes after..so use the simple one if you don't have the other mentioned above..
  • Goodluck!!!!
Feb 20, 2011 | Toshiba Satellite M35X-S161 Notebook
Tip
How to reset or remove BIOS password
There are four common categories of solutions to remove or reset a BIOS password and here are the details on how to go about resetting your BIOS password.<br /> <br /><b>Manufacturer Backdoor BIOS Password</b><br /><br />Most of the BIOS makers have set a backdoor password on the older computer models. That is the master password for BIOS. To reset BIOS passwords first you need to check the manufacturer of your computer's BIOS. Most computers have BIOS include AMI, IBM, Award, and Phoenix. These are the most common BIOS. You can unlock your locked BIOS using this master password. It works, no matter what the user sets the password to. Many popular computer and laptop manufacturers such as HP and DELL lock the BIOS because they want to protect their machine's most sensitive areas (those areas which have warranty) from their customers. These passwords are usually used by computer technicians for testing and repairing. <br /><br /><b>Reset the jumper that holds the password<br /></b><br />Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.<br /><br /><b>Removing the CMOS Battery to reset the BIOS to default</b><br /><br />Switch off your computer, and open up the case. You'll see a circular metallic silver item on motherboard. This is called CMOS Battery. Remove it carefully, and leave it out for about 2 minutes. This act will remove the CMOS memory which contains BIOS password. Set the CMOS battery back and switch on the computer. Restore the CMOS configuration as default. Your BIOS password has been cleared now. <br /><br /><b>Using third party software utility to reset BIOS password</b><br /><br />To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website <a href="http://www.hirensbootcd.org/">http://www.hirensbootcd.org/</a>. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
on Dec 12, 2010 | Computers & Internet
How to reset the BIO Password..???
Hi, Reseting the BIOS password is quite easy, you just need to unscrew the bottom plate and look for the CMOS battery underneath. all you need to do is to remove the battery for a few minutes then plug it back in. you should be able to go to your BIOS setup screen.
Thank you using Fixya. Your recommendation is highly appreciated.
Sep 28, 2010 | Lenovo 3000 N100 Notebook
Unable to reset bios password - removing coin cell battery had no effect
Then you can try it out by removing the jumper.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password.
The location of this jumper varies depending upon the motherboard brand.You should read your motherboard
manual to check its location.If you don't have the manual then look for the jumpers near the CMOS battery.
Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS etc.When you find the jumper,look carefully.
There will be 3 pins and the jumper will be joining the center pin to either left or right pin.What you need to
do is remove the jumper and join the center pin to the opposite pin.e.g.if the jumper joins center pin to left pin
then remove it and join center pin to right pin.Now wait for a few seconds and then again remove the jumper and join
the center pin to left pin.Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Feb 02, 2010 | Dell Inspiron 1501 Notebook
Please help me reset my bios password on acer travelmate 2410
First you need to remove the laptop battery at the back side. Find some screw there and remove it locate the CMOS battery and jamper.
The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is.
If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
Oct 08, 2009 | Acer 4220-2346 Notebook
Forgot password for bios setting
For this issue if you need to fix it with your self you need to follow the instruction from me. First you need to open your unit. Locate where the CMOS battery located.
Oct 08, 2009 | MSI K8MM-V Motherboard
How to get toshiba bios password remover toos
ok what you will need to do is reset the bios. just take out the bios battery for a couple ofseconds then putit back in this normaly resets the password Regards Slitwrists
Jun 08, 2009 | Toshiba Portege S100-S1133 Notebook
How do I reset my lost bios password for Dell Precision M70
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
Bios password
hi
you will have to reset the bios.open the system unit, locate a small battery, near the battery, there should be a small jumper. pull the jumper upwards, you will get a small square plastic cover. now turn on the pc, and your bios password is reset.
hope it helps
kind regards
Mar 11, 2009 | Intel D101GGC Motherboard
Remove bios password
There are lots of tools/software available to reset bios password. Just google for "reset bios password" and you will find one of them, else just open your back side of your notebook. Open the screws and remove the bios battery (a circular shaped sitll battery). If possible change the battery with a new one or keep that battery out of laptop for some time. Now start notebook without the battery and shut down.Then reinsert the battery to laptop and start again. The password should be resetted by this process.
Feb 17, 2008 | Computers & Internet
Dell Vostro 1320 Notebook Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
