Question about Ovens
Frigidaire caprice double oven need new seals around doors.can I buy them and are they easy to put on.
fridgetech
  • 473 Answers
SOURCE: 326B1230P001 GE double oven
You can go to http://www3.sears.com/ or http://www.appliancepartspros.com/. You will need the complete model # from the sticker on the oven. The # listed above is not correct. It looks like a serial #.
Posted on Nov 07, 2007
Master_Tech
  • 770 Answers
SOURCE: Frigidaire non-digital (old) Caprice top electric oven not working
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
Posted on Jan 21, 2008
  • 1314 Answers
SOURCE: installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
Posted on Feb 13, 2008
SOURCE: oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Posted on Apr 11, 2010
heatman101
  • 43501 Answers
SOURCE: F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jul 30, 2010
I have a Frigidaire Caprice double oven, 45 years old, the inner glass panel on the top oven door has shattered. I am not having any luck with finding replacement glass, any ideas?
take a profile of the glass shape (cut out the shape from cardboard) and go to a glass supply shop ( glass windows , doors , shower screens etc)
they should be able to cut and then temper the glass to make it heat proof for the door
if they cannot temper it they should be able to tell you where you can get it done
Nov 12, 2016 | Frigidaire Ovens
Doors are not sealing are the doors adjustable it's a classique double oven MODEL CLDO67SS 187014 (AK800-B7OP2-S403)
Check your door hinges, they may be bent. If so, you might be able to bend back, or buy new hinges. Might be a faulty seal
Nov 03, 2016 | Ovens
How to find candy double oven model number
should be by the main oven door seal
May 19, 2014 | Candy Ovens
Hi I have a Bosch Double Oven/convection Oven I
Don't know but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal.
Oct 04, 2013 | Ovens
Oven door window has streaks
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Frigidaire Caprice Oven won't work
i have a double caprice oven and the top oven wont go - something to do with timers
can u help
May 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Apr 26, 2009 | Frigidaire FEB27T5D Electric Double Oven
How do i fit new door seals for an neff u1421 double oven i have the seals
If the seals have what appears to be hooks at the corners, then unhook the old seals and re hook the new seals into the holes in the front of oven .
If no hooks, then the front of the oven needs to be unfastened.to replace the seals.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
10 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
