Question about VeriFone VX510
Power Failure Recovery - VeriFone VX510
Exelon DVR recovery mode
If you remove the power for 3minutes, that will allow the DVR to reset. Plug it back in and let it initialize.
Dec 28, 2013 | Computers & Internet
HD-338-COMP external hard drive not mounting
It's likely your dealing with hard drive failure on your san max and you will need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Computers & Internet
Disk boot failure on compaq presario S7300CL
Hi friend,
The message, "Disk boot failure" often means that the OS is corrupt and needs to be re installed. Try restarting the computer twice or thrice and check whether you can log in to the system. If the same error displays again then you have to re install the OS. But re installing the OS leads to data loss from the hard disk. So at such kind of situations you need a data recovery software to recover your data back. Yodot Hard Drive Recovery is a wonderful data recovery software which performs recovery after disk boot failure.
Jan 12, 2012 | Computers & Internet
My acer 5232 will not boot up. The power is on and eventualy give a failure message suggesting to insert recovery disk. I do not have a recovery disk. It was taking a long time to boot before this...
Sounds like the disk drive has errors probably caused by a mechanical failure. You had a number of previous failures before this one and the disk is most likely unusable.
A local computer shop (not a big box store) MIGHT be able to recover your data but not your programs.
Hope this helps. I would appreciate your feed back.
Oct 01, 2011 | Computers & Internet
Seagate HDD Harddrive 320 GB:How To Get Data Recovery?
Connect HD in another computer as a slave drive.
Nov 28, 2010 | Seagate Computers & Internet
Harddrive problem
Loud clicking means the drive is on the verge of complete failure. It might be possible for a data recovery expert to retrieve your data but you should not plug it in at all until they attempt data recovery. Running the drive will only speed up it's failure and it should only be run to do the data recovery. Some techs (like myself) can do software data recovery until the drive stops spinning, usually for $200 to $300. After that, it will have to go to a clean room which can run from $500 to $2500 to retrieve data depending on the amount of data and the procedure used to access the data on the dead drive.
Feb 09, 2010 | LaCie (300728U) 250 GB Hard Drive
Recovery pro lost power during my recovery of origonal settings
You can still install windows xp without the recovery disc. Just buy a windows xp installer then download the v2 premier driver in the net.
May 04, 2009 | Viscom V2 Premier 17'' LCD Computer...
Pc restarted
Irrespective of being a PC or a Mac the computer system behavior and consistency are dependent upon certain factors. These factors are broadly divided into software factors, hardware factors and the surroundings.
The common software factors leading to a logical failure are:
i.) System files responsible for handling control to the operating system missing or corrupt
ii.) Unsigned drivers or drivers trying to access read only system area
iii.) Operating system files corruption due to incomplete automatic update, malicious software
The common hardware factors leading to a physical failure are:
i.) Problems related to mainboard in terms of the chipset or connector, power supply issue like incompetent power supply to run the hardware setup
ii.) Problems related to hard drive itself or the data or power cables
iii.) Improper setup of hard drive cooler fans (if any)
The common surrounding factors leading to data loss are:
i.) Heat dissipation issues related to closed or poorly ventilated surroundings like in a basement or store
ii.) Moist surroundings leading to the formation of thick dust layers and thus increasing heat
iii.) Direct sunlight leading to extra heat and thus hardware failure
We should logically negate these scenarios so that we can narrow down to the root cause of the problem and take corrective measures.
In case we find that the data loss is due to any logical failure, we can use data recovery software as they are programmed to meet the challenges due to all kind of logical crashes. They scan through the file system, locate all the files which are marked as deleted and are distributed as fragments across the partition, logically rearrange them as per the file system information and then recover them. The data recovery software are indispensable in cases like file system corruption, hard drive formatting operating
system corruption, accidental file deletion or malicious software like virus, spyware etc. We can perform a ‘Do It Yourself’ data recovery using these utilities as they are self descriptive and User friendly.
We need to install the data recovery software on another hard drive which is bootable. We can also use a different working system preferably using the same operating system platform as for MS Windows. Then, we can attach our hard drive to the same for scanning. For attaching the hard drive we nowadays use USB 2.0 Hi Speed or IEEE 1394/Firewire Cables, Attachments or Enclosures. The same can be achieved by a Master and Slave setup that requires hard drive jumper operations and thus is a little complex. We should avoid any other jumper operations as of the mainboard as they may lead to unstable system behavior based on BIOS settings.
We should always save the recovered data on a healthy hard drive.
In case of data loss due to hardware failure where the hard drive is either not getting powered or can not be recognized by the BIOS, we need to go for hard drive recovery service. The data recovery service is personalized help, delivered by data recovery experts. Such experts can extract your data in all possible scenarios of physical data loss.
Apr 03, 2009 | Intel D101GGC Motherboard
Power failure message.
If the system is disconnected from the AC power it will not operate. Your announcemen and messages are retained in memory during a power failure but you will need to reset the clock. See the instructions on the bottom of the unit. If the message window displays CL, you need to reset the clock. See the instruction on the bottom of the unit.
Mar 11, 2008 | AT&T 1726 Digital Answering Machine
VeriFone VX510 Logo
Top VeriFone Retail Supplies Experts
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
