Question about Dual Universal Xgps 150 Gps For Ipad
Will not connect to foreflight on my ipod - Dual Universal Xgps 150 Gps For Ipad
Temperature transmitter? I am interested in a weather center app or product that will give me the actual temp outside my house ...and wind speed etc... Currently I have a display/receiver on my shelf and...
I have access to myPersonal Weather Station on my phone with 2 widgets:
1. Cumulus Realtime. Requires a PWS compatible with Cumulus software (free forWindows) and your own website for Cumulus to upload the data. The widgetaccesses the website to get readings at predefined intervals.
2. PWS Time and Weather. Requires a PWS and software such as Cumulus to uploadyour data to Weather Underground (Wunderground), which the widget accesses.
Jul 13, 2011 | ForeFlight Android Apps
Ipod is disabled and cannot connect to itunes as have new laptop
How to restore iPod
  1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
  2. Download and install the latest version of iTunes if necessary.
  3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  6. Click Restore.
  7. If you are using a Mac, you will be asked to enter an administrator's name and password.
  8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
    • Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
    Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
  10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
Apr 02, 2011 | Apple iPod touch
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
Dnx7100 ipod problem
The USB source is not for Ipods, from what I understand. The Ipod needs to be connected with the Ipod cable, $50 or so. I think it is a high speed connection.
Jul 07, 2008 | Kenwood DNX7100 Car Video Player
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance my ipod is not charged, when connected to a computer
hello!
if your IPod touch is not connected to itunes, please try the ff:
Check the iPod touch Display
-- When you connect iPod touch to your computer, the iPod touch should display an image or message on the display
-- If you do not see any image, check some basic troubleshooting here: http://support.apple.com/kb/HT1737
-- If you see a message on the screen, this indicates that the iPod touch does not have sufficient battery charge to operate and will need to be charged for several minutes before it can be recognized in iTunes.
Verify Windows PC System Requirements
--iPod touch requires iTunes 7.4 or later
Check USB Connections
-- iPod touch requires USB 2.0 to function properly
-- Try connecting iPod touch to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPod touch to your keyboard's USB ports is not recommended.
Restart your PC
-- In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
Verify iPod touch Driver/Service Installation
-- iPod touch requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPod touch the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service.
May 08, 2008 | Apple iPod touch
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
Dual Universal Xgps 150 Gps For Ipad Logo
24 people viewed this question
Top Dual GPS Experts
Will Halftowaite
Are you a Dual GPS Expert? Answer questions, earn points and help others
