Question about Convair Portable Air Conditioner
I have a convair prestige and I want to change the filter at the back, any ideas?
It's very old and it doesn't have any numbers after it, how do I get into the back of it to replace the filter?
Convair portable air conditioner won't turn on
Hi Corbi, the first thing you have to be sure if the right volatge is on the outlet box, 2nd, if the fuse on the A/C is good and may be, it sound like a yoke, if you have seen ans around your selector switch. If yes you know enough. I hope it was helpful to you!
Feb 03, 2014 | Convair Portable Air Conditioner
Where can I get a new aspen pad for a convair polar pride cooler?
This Aspen pad is avalable from a couple of sites, including Amazon which ships from hardwarehabitat.com, also from onlinehardwarestore. I used the following argument to search: "CONVAIR" ASPEN PAD COOLER REPLACEMENT PAD It is getting more difficult to find, mine is 7 years old. best of luck!
Jul 01, 2012 | Heating & Cooling
I need a belt for convair westwind swamp cooler Model M800CB UL serial #08 211046 Prod #: 008950 Belt runs from back of fan to the drive for the water pump. If you know where I can get one I would...
Hi John, your best bet for this, is to get the name and or number off of the belt, or take it off and go to any auto parts store and match it up. That's what we do in the field. If you try and order one, you will run in circles. Also, any appliance parts house will have one.
Shastalaker7
A/C Contractor
Jun 06, 2011 | Convair Portable Air Conditioner
Hi, Where can I get a thermal switch for convair 33mj wall heater
Hi.
If you are referring to the thermocouple, then part number is 880310. If you are looking for a different part, please refer to the part list below:
Convair Wall Furnaces
Part for this A/C can only be ordered contacting Convair, there are no third party online distributors. See: Convair Service
Sep 21, 2010 | Convair Heating & Cooling
Prestige not working.
This should fix itself...I once Prestiged and it sent me back to the first level of the mutiplayer. I believe this is an issue with the activision server
Jun 03, 2009 | Activision Call of Duty 4 Modern Warfare...
Convair  Portable Air Conditioner Logo
Top Convair Heating & Cooling Experts
Donni Steen
richie46
ray gallant
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
