Question about Kenmore Refrigerators
What is the cost of a kenmore refrigerator model 52542101
4 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
Posted on Sep 17, 2008
woodchuck789
  • 4059 Answers
SOURCE: My kenmore 52542101 is leaking
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Posted on Aug 02, 2011
imufo2
  • 3773 Answers
SOURCE: we have a kenmore fridge
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 26, 2011
I have Kenmore 52542101 refridgerator the is not cooling. I've cleaned the coils. Pulled the carboard panel off the back. The fan is running, the compressor is hot. The compressor click. The tubi
Sounds like a start relay, start/run capacitor or worn out compressor. Let's test the compressor electricall first. Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Ohming Compressor Windings Let me know I will be glad to help you.
Aug 06, 2012 | Kenmore Refrigerators
I have a Kenmore refrigerator model 106.56542400. The ice-maker does not work though the cold water works fine. How much it will cost me? Trying to see if buying a new one is cheaper. Thanks.
The cost depends on where the problem is. For example: If the ice maker is NOT getting water to make ice then it is probably the 2 line water valve solenoid or the sensor on the ice maker that would tell the 2 line water valve solenoid to send water up to the ice maker tray. Both of those replacements will cost you in the neighborhood of $25.00 - $40.00 plus a service call if you aren't able to do the work yourself.
If water is getting to your ice tray, but not kicking out the ice into the bin - that is usually a motor problem. And cost you as much as what a replacement ice maker would cost you.
To give you an idea of the cost of parts here is the layout for your unit: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10656542400/0582/0165000/K0707001/00012
Jun 24, 2011 | Kenmore Refrigerators
Kenmore 52542101 frig and it keeps running.
If the refrigerator is beginning to become too cold I would consider replacing the thermostat. If it's running and trying to keep things cold and not you may have freon loss or bad seals around the door frame. Let me know what the temperatures are in freezer and fresh food compartment, Sea Breeze
Sep 23, 2009 | Kenmore Refrigerators
My kenmore bottom freezer refrigerator keeps icing up how do i defrost it? model # 596.7182101
Sounds like the circulating fan is wearing out, this problem is very hard to diagnose because the fan still spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost for labor and material is around $300.00
Aug 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Not cooling, compressor kicks in for 3 seconds then back out
No the PTC relay on the compressor is bad. Need to replace it.
First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Apr 04, 2009 | Kenmore 53642 / 53644 Side by Side...
I have a Kenmore refrigerator/freezer. Model is 106 71192100. I just noticed a fair amount of ice build up on the back wall of the freezer unit. What could be causing this?
your defrost timer is not working repkace timer cost about 20.00 look at back bottom some on upper top ofin fresh food compartment near the light thanks from gilles
Jan 28, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106 52542101,WILL NOT EJECT ICE (SIDE BY SIDE)
Sep 17, 2008 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
