Question about Marantz Audio Players & Recorders
Marantz sr5007 amp the red light still flashing after reset??
Why int my marantz sr5007 amp working it shut off then after a factory reset the red light still flashes and i can no use turn the unit on?
tech48
  • 624 Answers
SOURCE: In a guest house and
Have you tried the reset procedure I am outlining below at the end of this post?
If you have not done it exactly this way, try it. The "protect" that is displayed is the protection circuit being activated. Most times it is activated is to prevent further damage to the unit. Sometimes it can be activated from the unit being over-driven (played at very loud volume for prolonged periods or having the improper speakers or a bad speaker).
If this reset procedure does not work, you need to take it in for service preferably at a Marantz authorized service center because the problem you are having is not something that can be fixed by any sequence of keys being pressed. It normally happens when the unit has a blown channel. That is not the only reason, but it is the most common reason.
If you have the proper tools, a schematic, and knowledge of how to check electronic components to know when they are faulty, you can then fix it yourself. If you do not have these tools and the proper skills, you can cause much more damage to the unit than you started with, even to the point of starting a fire or making the unit un-fixable. This type of unit is not an easy one to repair, even for a well trained electronic technician. I work at an authorized Marantz service center and have repaired many of these and other receivers over the past 17 plus years.
Be aware, by using this procedure and then turing the unit on can sometimes cause more damage to the unit if it has a shorted channel or other problem that makes it draw a lot of current. This method is meant for qualified service technicians to perform after they have checked the output stages for any problems and the unit is still in the protect mode. You have been warned, so don't say I didn't tell you it should be taken to a service center first. If you see or smell any smoke or buring smell, unplug the unit immediately. You may want to have one hand on the plug when you do this, just in case.
Here is the proper reset procedure:
SR4500 Turn the unit on (standby without pressing the power button), press and hold the 7.1CH INPUT and ATT buttons simultaneously for3 seconds or more.
If you have found this free information helpful, a "FixYa!" rating would be appreciated, and if you need any more help I am happy to offer it, just ask!
Dave
p.s. I have told you all the warnings and suggested a service center because this is a very good receiver and I would hate to see it damaged more than it may possibly have already. It is possible that this reset procedure will return the unit to normal operation, but more often than not, the "protect" circuit activating means that you have a serious problem that can not be fixed by anybody without the proper training.
Posted on Jul 09, 2008
localwonder
  • 6784 Answers
SOURCE: shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
Posted on May 21, 2009
  • 53 Answers
SOURCE: marantz sr6001 amplifier flashing on standby continuously
hi there
check settings for this configuration ......if you have a subwoofer in the settings, for best overall results choose subwoofer yes, and set main/center/surrround to small....if no subwoofer set left/right speakers to large and small to center, if there is no loe frequency effect (lfe) going to the subwoofer it will go into standby....hope this hlps ....shia
Posted on May 28, 2009
SOURCE: Standby light is flashing rapidly and I can't turn
RECEIVER MARANTZ SR7002, FLASHING THE STANDBY about 8 times per second and will not start, HELP
Posted on Sep 24, 2009
  • 137 Answers
SOURCE: Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Posted on Apr 20, 2010
SR4600 standby light on, what is the steps to reset. Red light not flashing but stays solid when powered on
On the SR6004 the factory reset is accomplished by holding the Surround Mode + Clear buttons for 3 seconds. You may need to check the last page of the troubleshooting section in your manual if your model is different.
Dec 30, 2015 | Marantz Audio Players & Recorders
How to connect apple tv to marantz sr5007 receiver
Apple TV connects via HDMI to the back of the amp.
Sep 03, 2014 | Audio Players & Recorders
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
Marantz sr5007 power supply dead
Have you tried a protection reset on the unit ?
Jun 22, 2014 | Marantz Audio Players & Recorders
Marantz sr5007 receiver dead after lightning strike
Hi Ridgep.
Replacement of the TOP258MG IC Should resolve your problem. Make sure you have fully discharged all the caps on the primary side of the power supply before fitting your replacement IC as they are very easily destroyed during installation.
May 08, 2014 | Marantz SR5007
Code for maratz sr5007
What is the brand name of universal remote control do you have?
Jan 11, 2013 | Marantz SR5007
Marantz sr5007 firmware update loop
hi am also having same issue, did you found the ans pls share me.
Dec 15, 2012 | Marantz SR5007 7.2-Channel 3D Home Theater...
Apr 17, 2010 | Marantz SR4002
97 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
