Question about NINJA SEARious Slow Cooker
Ninja cooking system e01
E01
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
I have an E01 error code on my West Bend slow cooker, how do I fix it?
Find out what the error code alludes to and rollup sleeves and .....................Could be something as simple as an open heating coil.
Feb 05, 2017 | West Bend Crock Pots & Slow Cookers
How to fix on a ninja crockpot e01
According to the manual it means the cooking pot is not inserted into the device.
Mar 19, 2013 | NINJA SEARious Slow Cooker
My west bend slow cooker has the error message E01. What do I do?
Here are the instructions from the West Bend Site
http://www.westbend.com/finditem.cfm?itemid=3940
heatman101
Feb 05, 2011 | West Bend 84596 6-Quart Slow Cooker
E01 code shows on screen. How do I erase this code if possible
Hold cook button in while plugging-in powercord . You might have to quickly hit the select button. If if doen't work the first time keep trying.
Jan 09, 2010 | West Bend 84396 6-Quart Slow Cooker
When I plug in my 84596 west bend it gives me eo1 with a beep
The E01 error message happened to me this morning. I unplugged the crock pot, held the "cook" button and plugged it back in while holding in the "cook" button. It seemed to reset itself. It is working fine now.
Jan 01, 2009 | West Bend 84596 6-Quart Slow Cooker
Crock pot
I had the same problem this morning (E01 error message). I unplugged the crock pot and held the "cook" button while I plugged it in. It reset and all is working fine now.
Jan 22, 2008 | West Bend 84596 6-Quart Slow Cooker
Display on digital reading
The site for West Bend is www.westbend.com you can read the FAQ to see if you problem is there or you can e-mail them with your problem.
Dec 21, 2007 | West Bend 84716 6-Quart
When I turn it on I get E01
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
WEST BEND SLOW COOKER
Dec 03, 2007 | West Bend 84496 6-Quart Slow Cooker
NINJA SEARious Slow Cooker Logo
381 people viewed this question
Top NINJA Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a NINJA Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
