Question about Hyla NST Vacuum Cleaner NST
Hose on hyla nst has hole in it - Hyla NST Vacuum Cleaner NST
Need user/owners manual pdf download for Hyla nst vacuum cleaning machine
Go to supececokeso.ga/4538658/62315-hyla-gst-repair-manual-bb342140 You should be able to find what you need.
Oct 14, 2017 | Vacuums
How do I remove hose from end that goes into vacuum cleaner?
if it is a convulated hose then it is screwed in to the fitting as if it is a left hand thread
the end section in the fitting is normally glued in to the fitting as well, so you will have to use a small flat bladed screw driver and pass it along side of the hose to break the glue
whenyou have the hose out cut off the bad bit or fit the new hose in after you put a small bit of contact cement in the thread of the fitting
Oct 31, 2015 | Hyla NST Vacuum Cleaner NST
How do I close off the hole to use the extension hose?
Some units do not have a close off. Simply connect the hose to the inlet or outlet and use to such up dirt, or dust off components.
Oct 30, 2014 | Shark Bagless Cyclonic Hand Vac, Blue
Can you wash canister and vortex assembly in Dyson DC17
you need a Hyla they use water as a filter and the smell goes down the drain
Jan 22, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hole in hose
according to the schematic it doesnt look like you can take that coupling apart. Usually when one has a problem with an electric canister hose its just easier to replace the hose because trying to shorten it without damaging the internal electrical wires and reassembling with the hose working is very unlikely. the hose part # is 43433113. you might have a hard time finding it tho. that hose was discontinued on 1/09 (same time that dirt devil bought out hoover and moved them over to china.) if you need anything else feel free to let me know.
Jan 06, 2010 | Vacuums
Hole in the hose
you are going to need a new hose
Dec 02, 2009 | Dyson Vacuums
Is there any way to patch a small hole in the lower hose of my hoover windtunnel bagless? I think my rabbit nibbled on one of the ridges.
Usually any kind of strong adhesive tape will do like electrical tape or carpet tape. A small piece should do it fine but if you can try and put a piece inside the tube so that the hole is sticky on the outside of the hose. Then put another piece over the hole on the outside to seal it. Its a tricky operation but if you are patient easy enough to do but needs very close attention. Also make sure that the tape is sealed across a flat part of the hose, not across metal ridges as when the hose is stretched the ridge part that usually has a metal coil inside will stretch and is no good for any hose if a hole has been made against the metal part.
Apr 01, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hyla electric brush won't work
Where can I get a Hyla vacuum instruction manual?
Jul 28, 2008 | Vacuums
Hyla NST Vacuum Cleaner NST Logo
23 people viewed this question
Top Hyla Vacuums Experts
Are you a Hyla Vacuum Expert? Answer questions, earn points and help others
