Question about Kenmore Dryers
Kenmore gas dryer model 72952100 does not start
Must hold down start button to run
  • 95 Answers
SOURCE: must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Posted on Dec 30, 2008
SOURCE: Kenmore Dryer
I had this same problem a couple of years ago. I replaced the circuit board located in the top part of the dryer and it has been fine since. The part cost $95 over the internet.
Posted on Jan 12, 2009
SOURCE: Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Posted on Jan 26, 2009
  • 686 Answers
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Posted on Apr 18, 2009
maddogsteve1
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
Kenmore Elite 11072972101 gas dryer will not stay on after I push the start button. What is wrong and how do I fix it.
If you HOLD the start button down and the drier heats and runs, then your problem is most likely a relay which is supposed to energize (close contacts), which "latches" the condition when you push the start button. The most likely cause of such a failure, is a fuse or a thermal cut out, which has prevented normal operation. For safety reasons, being a gas appliance, I would NOT ATTEMPT to fix this problem yourself, unless you have licenses to service such equipment!
Apr 17, 2017 | Kenmore Dryers
My Kenmore gas dryer starts but does not stay on
This is very likely a relay problem. There is a black relay in the control head that engages when the start button is pressed. The relays tend to go bad now and then. They are a simple replacement and cost less than $15 or so.
Sep 26, 2014 | Kenmore 73952 Gas Dryer
I have a 2002 27" kenmore elite gas dryer that runs great except you have to hold down the start button. I took it all apart and cleaned it. The motor looked fine. I think it might be the start button.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore Dryers
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Dryer won't run except when start button is held
you need a new start button and switch
Jan 12, 2009 | Kenmore Dryers
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Kenmore gas dryer will not start model 110 72972109
check your motor relay under your control panel
Dec 23, 2008 | Kenmore 62802 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
psrao, right next to the timer under the consol is the even heat board. When this fails, it will cause this problem. This has been an issue with this model. Part number for the board is 3978949. Catriver..post back.
Jan 14, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
