Question about Aztech HW550-3G 300Mbps 802.11n Mimo 3G/3.5G Wireless LAN/Firewall 4-Ports Router w/USB Supports 3G ...
Hw-550 3G cannot initialise - Aztech HW550-3G 300Mbps 802.11n Mimo 3G/3.5G Wireless LAN/Firewall 4-Ports Router w/USB Supports 3G ...
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Apr 08, 2014 | 1996 BMW 540i
How do i initialise black toner for 2051c
No need to initialise toner.
When toner low, just replace the toner via the control panel.
Mar 27, 2014 | Toshiba e-Studio 2051C Multifunction...
How could i hook up my hw-f350-355 to my samsung no sound
http://www.samsung.com/ie/support/model/HW-E350/XU-downloads?downloadName=UM
This Samsung weblink for will allow you to download the manual for your product in .pdf format. See page 12 for HDMI ARC connection, page 13, for analog connection.
Did you turn on the power button? Happens all the time.
Dec 01, 2013 | Samsung HW-E350 Crystal Surround Air Track...
My shower water temperature is way too hot. How do I reduce it?
go to the hot water heater and turn it down 1\2 way a start from there
Jul 19, 2011 | Heating & Cooling
My husbands little camera when you turn it on flashes "E:91:01 his camera is a Sony cyber shot DSC-W50
You need to re initialise your camera.
You will find this function in the menu under set up.
If you can initialise, you will not lose your pictures that are already on the camera.
If you cannot get past the error to initialise, go to live chat at Sony esupport:
http://www.docs.sony.com/startchat.asp?modelnum=&chat=1
Regards Robyn
Jan 08, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Every time I open my pc,black screen displays. Then after the OS displays after that nothing. & after a minute it repeatedly displays the same. What' the problem with my pc?
The PC boot detection can be troubleshooted in stages.
I am just getting the process explained here. If your boot issue falls in any of the below said stages, Please do the needful as per the suggestion.
Stage: 1 When the Signal chip on the motherboard initialize the post operation and it checks for the Motherboard powersupply, baised on the Bios manufacturer you get a signal once the POST (Power on Self Test) finishes.
Suggession: If there is any problem at this point, the system hangs\or stops working as Bios wouldnt start its routines. You may have to contact a HW Engineer to find the solution.
Once the POST is done successfully, the Bios is initialised with the Routines to run a check on the motherboard, ports, devices attached and it inspects all chipsets and hardware details of the system.
This point you will see the tiny LE-diode flashing on keyboard and other attached devices. Cmos is loaded with the detailed HW information. As a heirarchy of inspecting the Hardware, it checks for the Audio first and then the Video chipset and status.
Any beep heard multiple or single long at this point could also be due to the failure of Display chipset or port or device. As the system cannot indicate the failure it uses audio. Here your VGA once detected it starts giving you either a non-graphic or graphic display of whats happening inside the system. (Boot process). Suggessions: Any issues at this stage needs to be fixed either on HW or Peripherals attache or finally on Bios if corrupt.
Once Bios routine is done the control transfers to a small program on Bios called bootstraploader which helps in finding the boot up files on the Active partition and initializing them. Here if it fails to find the boot files it shows the message usually known as "Non bootable disk"
Suggession: you can finalize understanding that the disk has no boot files or they are corrupt or the disk partition that has the boot files is not readable.
Suggession : 4: Once the windows starts loading and still it gets stuck at any point till you log on its all the OS files which plays its roles to get the system up. If there is a failure at this point, your OS is corrupt or has an issue. Suggession : Please do an OS Repair or at worst case and OS reinstallation. Hope this gives answers to your issue. Good Luck.
Feb 16, 2010 | Microsoft Computers & Internet
Game won't initialise. When I start it, just before reaching the start menu (after cinenatics) I get a popup saying it won't initialise and everything shuts down. I've tried reinstalling and deleting saved...
if it says "initialising failed" (or something like that) start the game in safe video mode:
  • press start
  • go to all programs
  • microsoft games
  • age of mythology
  • diagnostics
  • AoM-safe video
and it should work.
Jan 04, 2010 | Microsoft Age of Mythology for Windows
When I put the sd card in and then turn power on it ask to format. no matter if I input yes or no the camera then shuts off
i have this w5 camera for the last 3 years few months back an error appear named E;91: like that and sometimes a beep sond for few seconds also on flash mode i cant take pictures i solved that problem by initialise the settings.now that problem started i initialise and formatted also remove the memory stick and again initialise and formatted but the error continues.i can only take pictures without flash what can i do please give me ur valuable suggestions
Oct 12, 2009 | DXG Technology DXG-572V Digital Camera
Changing a -vr format
You're right - only DVDs initialised in VR mode can be edited on the camcorder. Those initialised in VIDEO mode cannot be edited on the camcorder, but can be played on most DVD players and can be edited on a PC.
The good news is, if you are using a DVD-RW disc you can change the mode by reinitialising it to be in VIDEO mode, but you will lose all the previous content during initialisation. DVD-R discs cannot be initialised.
See this Fixya solution for details on how to initialise a disc.
To Junie1939 - No, it's not possible to change a DVD from 'plus' format to 'minus' format, sorry - you have to go buy 'minus' format DVDs, or change the DVD reader on your PC. Remember the Canon DC210 only takes 'minus' format DVDs.
Don't forget to rate this solution once you've tried it !
Good Luck.
Apr 27, 2008 | Canon DC210 DVD Camcorder
Aztech HW550-3G 300Mbps 802.11n Mimo 3G/3.5G Wireless LAN/Firewall 4-Ports Router w/USB Supports 3G ... Logo
35 people viewed this question
Top Aztech Computers & Internet Experts
Ali Reza
Level 1 Expert
James Van Damme
James Van Damme
Are you an Aztech Computer and Internet Expert? Answer questions, earn points and help others
