Question about Mitsubishi HS-U520 VHS VCR
I just bought a used Mitsubishi HS U520 VCR recorder and cannot set the timer recording mode past the year 2010. Can this be corrected???
Can't set clock time/date past the year 2010.
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Posted on Jan 18, 2008
SOURCE: set vcr to record a program later
The VCR has to be off for the timed record to work.
Posted on Apr 18, 2008
SOURCE: Mitsubishi HS-u59 video cassette recorder
how do i unlock the vcr plus on mitsubishi hs-u59
Posted on Oct 29, 2008
SOURCE: Mitsubishi HS-U500
Just set it to record"today" choose the correct day and month,the year will be unimportant.
Posted on Mar 24, 2009
SOURCE: CHAGE SPEED FROM SP TP EP
If I remember correctly there is a switch on the front behind a small door that you pull open.
Posted on Jun 19, 2009
Purchased in 1996. The date setting does not extend beyond 2010
No only in service can if it posible to reprogramed the EPROM.
Mar 11, 2010 | Televison & Video
My vcr will not recognise the year 2010 it goes back to 1990 so I can no longer use the timer to record when I am not there.
All depending on when your unit was manufactured, it might not support the year 2010. You will have to upgrade to a new VCR or DVD player to use the timer record function. Good luck to you!
Jan 01, 2010 | Philips Magnavox MWR10D6 DVD Recorder
Sir,just bought vhs vcr hsu520 mitsubishi from seller and
Have you tried the Mitsubishi website? Sometimes firms put up free a PDF of the user manual.
Oct 24, 2009 | Mitsubishi HS-U520 VHS VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Set the timer to record
Do you have the remote which came with it? Most VCRs of the last 10 years require the remote to setup a timed record, or for that matter, most of the advanced functions- beyond play/rewind/ffwd, etc.
Assuming you do have the remote, and the correct time is set, and the timed record properly setup, some VCRs require a the On-Timed-Record button to be pushed. This sets the VCR in a wait mode, until the time set for the recording to begin.
Consult your owners manual- an online manual may be available if the printed one is missing.
Mar 04, 2009 | Sharp VC-H812U VCR
Can't get a picture on TV screen
I think the tape is blank. I mean not recorded.
Oct 24, 2017 | Mitsubishi HS-U545 VHS VCR
Mitsubishi HS-U500
Sep 24, 2008 | Mitsubishi HS-1280U VHS VCR
You will have to choose a year that corresponds to the days of the week. In other words, the processor has not been designed to accomodate that far into the futured\...accordianman
Feb 11, 2008 | Mitsubishi HS-U775 S-VHS VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Set vcr to record a program later
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Televison & Video Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
