Question about Singer 14SH654
One of the two lower needles (inside needles) were touching each other and one broke
2 Suggested Answers
SOURCE: When the needles go down the lower looper move on
I have a Singer 14SH654 Serger, trouble started when I broke a needle. I replaced needle now it does not sew properly with two needles. Can anyone help me
Posted on Jul 30, 2010
I have a funlock 004D/004, the lower looped broke and I replaced it with one I ordered online. It makes a chain when I run it but when I try to sew fabric nothing catches. Any suggestions?
you have to make sure the looper is properly positioned. With the screw loosened slightly you should be able to move the looper up and down slightly, thus adjusting the timing. You are looking for the lower looper tip to come in slightly above the needle eyes, as close as possible without touching. Then the upper looper must come in right behind the lower looper "head" as close as possible without touching. The upper looper should then extend past the left needle by about 2-2.5mm, and the needles will come down before the eye of the upper looper returns to the right.
Dec 12, 2016 | Sewing Machines
Stitches are not locking at all and all that happened was needle broke
are you saying after you replaced it this happened? I think you don't have the needle low enough. Just undo the needle screw and lower the needle a "tad"
Oct 07, 2014 | Sewing Machines
Thread broke on bottom looper the first time out of box i had to try and thread and the tension was still tight The bottom threads were not stiching
I'm going to assume here you're talking about a serger. Unthread the lower looper and the eyes of the needle. Set the lower looper tension to 0. Rethread the lower looper, then the needle eyes. Then reset the lower looper tension (try about half a number lower) and see if it chains. If it won't chain, try replacing the needles.
Mar 17, 2014 | Janome Sewing Machines
How to set timing and bobbin in my juki ddl-555
hi there
when you need to set timing please first make sure height of needle bar is ok. there's two mark at needle bar, the upper one is for height of needle bar: bring the needle bar at lowest position and in this case the upper mark must be equal with lower needle bar bushing.
second : set timing
move hand machine pulley at the same rotation and when the lower mark equal with lower needle bar pushing the tip of hook must be at the center of needle groove and just light touch not hit. that's all
best regards
ashraf abozid
CAIRO - EGYPT
Nov 29, 2012 | Sewing Machines
My needles hits the lower loop on my 16sh644 serger and the thread from my needles won't stay wrapped around the lower loop lever
it's very possible that the machine is out of time & needs to be serviced at a sewing machine shop
May 26, 2012 | Singer 14SH654
When the needles go down the lower looper move on the back of the needles goin up the lower looper moves in front of the needles and causes the thread brake and makes a craking sound when the lower looper...
Jul 03, 2010 | Singer 14SH654
Timing on a Huskylock 535D surger
the eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Kent
Feb 07, 2009 | Husqvarna Husky 165
Mock safety stitch
Sounds like the timing is a little out.
If you remove the needle plate and turn the handwheel manually watch for the lower looper as it swings behind the Left needle....the needles ought to rise by only about 2mm before the looper passes......the looper must pass the needle above the eye to catch the thread, and be so close as to be barely touching the rear of the needles......if the left needle thread is not picked up, it may be the timing, or the distance between needle and looper.
For the uninitiated, there are a myriad of variables in correctly timing an overlocker (serger), and without the manual to refer to the correct parameters, you will rapidly descend down a road of despair....if you move a looper to advance or ****** the timing, you risk looper collision and a broken looper is almost as much as a service, so my advice is do the test to see if the timing is the likely culprit, and if so, take the opportunity to give the old girl a treat.
If you need to save for a while to do it, just use the 3 thread option for the time being.
www.bargainbox.com.au
Apr 26, 2008 | Singer 14SH654
Lower loop broke- do I have to start from step one?
yes, take all threads out, and re=thread according to the diagram, following the threading order.
Mar 02, 2008 | White Sewing Speedylock 1600 Mechanical...
Singer 14SH654 Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
