Question about Home
Skycam atomic clock
Outside temperature doesn't display
4 Suggested Answers
  • 3 Answers
SOURCE: outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Posted on Jan 15, 2009
  • 10865 Answers
SOURCE: Outside temperature not working on
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Posted on Feb 18, 2011
cprgolds
  • 16 Answers
SOURCE: Outside temperature doesn't display on atomic
Suggest you check the quick reference manual at:
http://www.skyscaninfo.com/content/quick-ref.html
Posted on Nov 12, 2011
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Can reset everything on my SkyScan Atomic Clock except for the outside temp. Have new batteries in both units. Main clock and outside remote thermostate..Any suggestions??
I expect that since the unit reads the outside temperature from the remote thermostat, there is no need to "reset" the displayed number since this data is obtained live from the thermostat.
Nov 04, 2015 | Home
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
My atomic clock won't show the outside temperature and I can't get it set for regular time, it only shows military time. How do I fix these two problems?
Hi
If you have lost the outside temperature on the clock display then do the following:-
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappears.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
Also check the link bellow:-
http://www.ehow.com/how_4597931_set-atomic-clock.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 31, 2011 | Office Equipment & Supplies
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
Outside temp on skycam atomic clock
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Changed batteries
Also,
Sep 07, 2008 | SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
21 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
