Question about GE JSP42 Electric Kitchen Range
Hot surface light stays on
Hot surface indicator light stays on even when cool
5 Suggested Answers
reg501
  • 413 Answers
SOURCE: GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Posted on Jun 05, 2008
SolutionGuy
  • 331 Answers
SOURCE: I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Posted on Apr 12, 2009
MNTECH
  • 1543 Answers
SOURCE: GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Posted on Jul 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have a GE stove that has a red light for HOT SURFACE
The control switch for the right front burner is bad. A new switch will solve the problem.
The situation,while annoying is not dangerous.
Posted on Feb 18, 2010
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
The light for the right back burner stays on,even though the burner is turned off and is cool
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Dec 25, 2010 | Microwave Ovens
mvek,
SG
Apr 11, 2009 | GE Kitchen Ranges
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
