Question about Kenmore Refrigerators
The start relay on Kenmore model 596.58642890 replacement question
The start relay went out on Kenmore model 596.58642890. The old part had four plugs, but the new part (67005560 Whirlpool Refrigerator Relay Overload Start Compressor Start NEW OEM) only has 2 plugs. Which plugs plug into new part, and what should be done with other wires?
  • 46 Answers
The original relay switch has 3 terminal contacts on the compressor side. On the wiring side it has 4 contacts... 2 are start capacitor connections and two at the bottom of the relay are the A/C 110-125 volt line in connections. The replacement part you bought is a genericreplacement for the ref. The correct substitute part is W10189190 . The two wires for the original relay in the top horizonal position evenly spaced apart... ignore the 2 wires. They are wires to the old start capacitor mounted somewhere near the compressor. The other two wires are important to configure them properly. One may be blue and the other red. Here is a cheap way to know which is the right configuration... Use a volt ohmmeter and check the continuity from the refrigerator ground terminal on the A/C line cord or chassis to both A/C line in wire connections to the relay. If the ohms are zero or very near to zero then that is the ground/ aka neutral wire. The neutral wire connects to the bi-metal overload protector built into the relay. That is the bottom center connection terminal on the compressor. The other A/C line in wire is the hot wire and it connects to the Start/ Run connection on the new relay. http://www.appliancezone.com/ShowProduct.aspx?ID=28271
OR
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/10097202/0046/596/Model-59658642890/0582/0165000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=P8090243&diagramPageId=00010&productTypeId=&searchModelNumber=59658642890&subCompDesc=Machine%20compartment/muffler&brandDesc=KENMORE&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&blt=11&shdMod=59658642890&keyId=251
Posted on Feb 08, 2014
docjohn174
  • 943 Answers
SOURCE: start relay on my whirlpool fridge
hi thanks for the question the white wire goes to the pin on the left the red on the right black at top thanks the appliance doc
Posted on Sep 28, 2008
  • 27 Answers
SOURCE: kenmore fridge start relay wiring
there is no need to shroten the lengths of the wires, u can directly connect it
Posted on Mar 10, 2009
  • 159 Answers
SOURCE: Overload relay bad ordered new one part# 67005560 pulled old relay out and it has different connection did I order wrong relay?
normally it a replacement part but overload is a clickson
Posted on May 22, 2009
  • 401 Answers
SOURCE: I just replaced the start relay (start device) on
Leave the capacitor on and don't worry about the cover. The capacitor really helps the compressor to not use as much electricity, thus saving energy.
Posted on Jan 06, 2010
localwonder
  • 6784 Answers
SOURCE: kenmore refrigatorstart/relay/overload switch has burned spot on
HI. i would recommend to check the relay first, then the compressor last to confirm total failure. If both devices test out ok, this will lead to a failed main power control board.
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On some units. the relay may not be covered at all.(each model may vary). Beneath the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the compressor motor are located here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each model). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it should be replaced asap.
COMPRESSOR TEST PROCEDURE
The compressor is accessed from the lower rear of the refrigerator. Generally the same proximity of the relay. The compressor motor can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. The main testing points will be the actual terminal post that hold the relay, gently pull the relay of the terminal box on the side of the compressor, and use the relay holding probes for testing. Once the relay is removed, Place one probe on any terminal and then touch the other probe to each of the other two terminals. The multimeter should display a reading of zero ohms. Be sure to set your meter to 1X before beginning. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multimeter displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multimeter still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multimeter should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service.
Posted on Jan 10, 2010
Kenmore Fridge model 79558813900 which is a year and a half old randomly went completly out not sure what to check. It is not the fuse or the plug.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If this doesn't work Do this
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Kenmore Refrigerators
I have trio 795 model. It beeps. Temp goes up. Checked temp setting. Both freezer and reg settings are ok. Turn off the power. Turn it on again. Still beeps. Fan doesn't work and it is not cooling....
Hi!
If thats what is happening with yours
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one.
If you still have trouble Go Here:
Leo Ponder
Aug 15, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore refridgerator not blowing cold air.
You need to replace the overload/relay . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . It is easily replaceable . Take your model number with you when you get the part kit , so you get the correct replacement . DO NOT use a 3 in 1 hard start . This item is used by inexperienced technicians , and will only last a short time . Get what is called for , for your refrig .
Nov 04, 2009 | Kenmore Refrigerators
Push to start switch only works when held in.
Go thru the back to access the push to start via 1/4 inch screws. More than likely the push to start isnt the problem with the heat issue. i would lean towards the motor relay and the heater relays that are on this unit
May 27, 2009 | Kenmore 659 Electric Dryer
Kenmore model 253 fridge cools then issues....
Ye, try to first replace the Relay, if that does not help then go to the run capacitor. Those are going to be your only 2 problems that you will have as long as the compressor is still doing its job by atleast running
Feb 09, 2009 | Frigidaire FRS26RLECS Side by Side...
Kenmore range
You said, you have a 12 year old Kenmore Range. Smooth-top, over which only 3 eyes now work.
And you've lived with this for a couple of years. But now the bottom element burned out.
It sent sparks flying as it glowed brightly and released fire as this bright spot moved around from one side of the element to the other and finally went out.
You would like to replace whatever is needed.
Please help determine what is needed.
This is the old model # PLT083-2. You see it inside the door.
My advice is that after 12 years and a number of failures. especially the sparks!
You should replace this range! Do not put good money into bad!
I believe you deserve the pleasure and comfort of a new range before the holidays!
Here is a report I just read !
I believe it will help you decide and you may find it very interesting!
Repair or replace you appliances?
When to pull the plug on your old Appliance
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your appliance,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your appliance is under warranty or less than four years old
paying for a repair makes sense.
Note that appliances under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your appliance is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new appliance.
Data also shows that it doesn't pay to fix a less-expensive appliance
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a appliances you replace is likely to end up in a landfill.
I believe I may have solved your problem, with some Profesional sound advice!
If you have any questions feel free to ask!
Please remember to leave me a solved rating before you sign off!
Thank You, HUUUM
Oct 01, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Sep 20, 2008 | Kenmore Elite 20972
Kenmore dryer king size capacity 90 series
Sorry to say, but the motor needs to be replaced. motor cost around $150... 9yrs old=not worth fixing...
Jan 03, 2008 | Kenmore 63942 Dryer
Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Dec 06, 2007 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
130 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
