Question about Verbatim Ac500gb 500gb Usb 2.0 2.5 External Hard Drive black AC500GB
Computer does not identify it
The light comes on on the hard drive and i can hear it running, my computer acknowledges something is plugged in (makes sound), but it will not come up as anything has been plugged in, i have tried this on many computers and tried different cables too
pankaj_dic
  • 1250 Answers
SOURCE: my hard drive is not working
check it on some different system if the problem persists then its the problem of your drive, if its under warranty claim it
Posted on Nov 08, 2008
SOURCE: external hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Posted on Apr 10, 2009
  • 733 Answers
SOURCE: my external hard drive doesnt show up on my
check to make sure it does not have a write protect switch on the device. if not, check device manager to see if you have harware conflicts.
Posted on Sep 12, 2009
bob_computer
  • 3153 Answers
SOURCE: I have plugged in my new Verbatim 160Gb external
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive
Posted on Nov 21, 2009
ynogami21
  • 670 Answers
SOURCE: My portable hard drive wont connect to my
hi there,
While the Hard drive is connected to one of the USB ports on your computer.
On your keyboard press and hold the power button and press the letter R.
When the Run box comes up type in devmgmt.msc
Expand the Universal Serial Bus cotnrollers
right click on every root hub and choose uninstall
after that restart the computer
Hope this helps!
Posted on May 05, 2011
FIREFLY MODEL USBFF20 Has for 10 or 20 years (?) and stil works in my old Dell. I recently bought a new Dell XPS 8700 w/Intel Core 17. Now, the light comes on, it makes mechanical noises like something...
I would suggest that you go out and buy a current generation external drive, connect the firefly and new drive to your old dell, pull the data off and crush the firefly. Why would you trust any harddrive over 5 years of age with important data. Plus if I am reading the model correctly this is a 20Gb harddisk which is not practical for current backups or storage due to increased sizes.
Jan 11, 2015 | Dell Computers & Internet
Hp mini. The problem I stated is that the computer is not reading or acknowledging the hard drive. I checked resources online and I was told to remove the hard drive and then put it back in (unscrewin
There are three things that may be wrong with the hard drive:
1) connection was bent when you dropped it2) motherboard was damaged when you dropped it3) HD was damaged when you dropped it
Are there any bent pins (gold looking needles on connector)?Does anything "jingle" or sound loose when you shake the computer?When you plug the hard drive in and turn on the laptop, can you hear it spinning?
If you cannot hear the hard drive spinning and the laptop is plugged in then I suspect the hard drive is bad.
Nov 16, 2012 | Computers & Internet
My hard has all of sudden is not being picked up by my pc or anything for that matter. The power light is flashing on it so I'm thinking it might be the power supply. What do you think ?
Sometimes it could be that it's not registering the letter for the drive. If you hear a chime when you plug it into the computer and turn it on, it is being recognized by your system.
If that is the case. Right-click on your "My Computer" icon, and click on Manage. Then go to "Disk Management". There, it will list your hard drive. You can distinguish it from your computer's hard drive by the size, and normally your computer's hard drive is set to Drive 0 by default.
Once you identify it, you can right-click and "Assign Letter Drive" and that should fix it.
If it does not chime (first make sure that the sound is on). You can try and see if there is a clicking, or a whirling noise. A whirling noise is a good sign. A clicking noise is not. If you hear nothing, then something between the connector to the hard drive inside is bad or the cord connecting the drive to the computer is bad. If you narrow this down, you can normally get the right cause.
I hope this helps.
Please Rate
Jul 08, 2011 | Western Digital Wd Elements Se 1tb...
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Harddrive not being acknowledged by laptop
This is a hard one, as 7 is so new. But it sounds like the very next thing to do is to plug the drive into another computer to see if the drive is working properly. If it works well, make sure that your drive is not trying to grab a drive letter that is already being used by another device. Do a search on the MS website for known issues and instructions on how to check for drive letter management issues. Good luck.
Feb 26, 2010 | Western Digital My Passport Essential...
My computer does not acknowledge my hard drive.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Nov 21, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
I have a Fantom Drive Titanium External USB 2.0 Hard Disk Drive. All of a sudden the drive in gone. I tired to unplug everything & redo but nothing appears. It does not have a disk. It is a plug &...
Hello
If you turn on the drive can you feel that the drive starts spinning? Can you feel movement and see a light flickering?
Does your computer acknowledge that there is something plug in when you plug in the Drive? Does it give you a notification, or does it make a sound?
If so, then this simple setting just might fix your problem.
Just follow these steps and you should be set.
Go to:
Start
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below.
Right click on the drive and choose to change the drive letter and paths.
Now click on change and change the current drive letter. If there is no drive letter assigned, assign one.
However, if the drive does not spin at start up, there is something wrong with your HDD.
Hope this can be of help.
Kind regards
Andrea
Nov 15, 2009 | Fantom Titanium USB 2.0 250GB 7200rpm...
Purchased Hitachi simpleTOUGH about a 1 mo ago. Now have issues!
My Simple Tough has failed early too, and I bet in the same way. It powers up and lights up but neither of my computers can recognize it. Have you come across a fix. Has Hitachi done good by you?
Aug 22, 2009 | Hitachi Computers & Internet
Mac won't acknowledge Mybook!
try restarting your computer with the mybook plugged into it. also, leave it plugged in for a while and check back to see if it shows up on the desktop. I had a similar problem with my hard drive too, and this seemed to work.
Jul 21, 2009 | Western Digital My Book Home Edition 500...
Dropped SmartDisk
email me on warewolf2001@hotmail.com and i'll see what I can do
Nov 11, 2006 | SmartDisk FireLite 40 GB Hard Drive
Verbatim Ac500gb 500gb Usb 2.0 2.5 External Hard Drive black AC500GB Logo
29 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
