Question about Craftsman Sears Snow Thrower Manual Model 536.886261
Replace auger on a Craftsman snow thrower 536.886261
Need to replace RH auger and need to remove housing assembly
  • 127 Answers
SOURCE: Craftsman Snowblower. One auger is
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Posted on Dec 27, 2010
ToolBoxHero
  • 171 Answers
SOURCE: I need a replacement belt
Sears will not tell you what size of belt you need. They only list parts by part number. But this machine uses MTD belts and you can get them at searspartsdirect.com or your local mower shop can order them through MTD.
Part Listing: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/Model-247886640/0247/1507200?sid=MMLxMerchandizexManualsModelxcraftsman%2088664x247886640
Manual: http://www.managemylife.com/mmh/owner_manuals/search?query=craftsman+88664
Here are the two part numbers for the two belts on the machine. MTD Part #: 954-0343
and #: 954-0430B
Any other questions, please ask. Remember to rate this answer if it helped.
Posted on Jan 11, 2011
  • 127 Answers
SOURCE: I have a Sears snow
many Sears/Craftsman snowblowers have a shear bolt on the auger shaft or one on each side. This bolt is designed to break under a specific amount of force to prevent damage to the gear box or drive assembly if the blades encounter an immovable object or something becomes jammed (even a newspaper buried in the snow can cause this). They likely broke at some point during use in the past and you did not realize this, or they were not properly installed when the blower was new. If you check the auger shaft and find one or 2 holes that look like something should be there, then you found the most likely problem. If you reply with the model I can tell you exactly where to look and the part # or if you realize the bolts are missing you can contact that parts dept at Sears with your model and they can provide replacement bolts. Can be a pain with small things but a lot less expensive than a new gearbox.
Posted on Jan 13, 2011
  • 4088 Answers
SOURCE: We have just installed the
This appears to be a Sears model number--go to: www.searspartsdirect.com and enter the model number minus the decimal point. This will bring up a series of drawings of all of the replaceable parts for the machine. Locate the pulley that you speak of and see if a 'key' is shown to lock the pulley to the shaft. Hope this helps!
Posted on Feb 01, 2011
  • 144 Answers
SOURCE: Snow thrower let auger not spinning with right
If you look on the auger shaft you will see some bolts, they are called shear pins. They are there to break if something gets in the auger and jams it, the bolts will shear off to prevent damage to the auger or something else. What you have to do is replace the shear pin or pins on the side that is not turning. Hope this is helpful. All the best and good luck.
Posted on Feb 03, 2011
News paper in auger
Hi Robert:
This can be really annoying and requires patience to remove.
If it's not freezing outside, a garden hose with the jet setting or a kettle of hot water can be helpful to soften the paper. Then use a sturdy knife or screwdriver to pick the paper out a bit at a time.
Hope this helps
Mar 11, 2016 | Craftsman Sears Snow Thrower Manual Model...
How do I remove the impeller from a 800 Gilson snow thrower
you have to remove the chute, then the auger bearings and any gearbox stabilizers. remove belt now turn auger while watching through chute hole until you see roll pins through your shaft. knock these pins through ( usually 2) then you can remove the whole auger assembly which reveals your impeller
Nov 01, 2014 | Garden
Where can I find detailed instructions on replacing an auger?
first remove the chute. then remove the bolts holding the auger in place. then rotate shaft by hand and find the two roll pins that hold auger assembly shaft. drive these pins out and you auger will slide out the front of unit
Aug 28, 2014 | Yard Machines 26" 208cc Two Stage Snow...
On my craftsman snow thrower the auger is stuck (jamed)
you bent it straighten it out as to where it works as it should , easy fix , did you get the bad tile out
Feb 14, 2014 | Garden
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
CRAFTSMAN SNOW THROWER
Check the sheer pin on the auger assembly. Could also be the belt needs adjustment or replacement
Dec 31, 2007 | Vacuums
Craftsman Sears Snow Thrower Manual Model 536.886261 Logo
82 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
