Question about Blueair 500/600 Series SmokeStop Filter (Set of 3) Air Purifier
Blueair hepa filter fuse - Blueair 500/600 Series SmokeStop Filter (Set of 3) Air Purifier
2 Suggested Answers
SOURCE: RED CHANGE FILTER LIGHT DOESN'T GO OUT AFTER CHANGING FILTER
I had the same issue.  Press and hold the 'TIMER' button untill you hear a beep and it will reset.
Posted on Apr 06, 2009
What size is the fuse on the Blueair purifier.
Hi there.
15 amp. Also remember there is a reason why the fuse is not working. Goodluck ..
Sep 23, 2017 | Blueair Air Purifiers
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Feb 24, 2014 | Blueair Air Purifiers
I have been looking to buy an air purifier and people keep telling me to get a HEPA. What does this mean?
HEPA is a type of air purifier. It stands for high-efficiency particulate air. To qualify as a HEPA filter by government standards the filter must remove 99.7% of all particles larger than 0.3 micrometers from the air. The following site lists the top 10 HEPA purifiers available online - http://www.air-purifiers-america.com/AP101_top10.asp.
Jul 12, 2012 | 3M "Replacement Filter, 11 7/8 x 18 3/4"
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
My blueair 501 suddenly stopped working. I turned it off to move it to another room, and it will not come back on. Outlet has power. Is there an internal fuse I can replace?
The power cord had burned out right at the point where it connects to the female receptable (the end that connects to the unit). Need replacement cord.
Jun 05, 2009 | Blueair 501 Air Purifier
Apr 02, 2009 | Blueair 250E Air Purifier
GE HEPA 106653
Where can I go in my town to get filters? I live in Vacaville,CA
Jan 23, 2008 | GE HEPA 106653 Air Purifier
Dead
check power outlet / test the Blue air power cable w/tester continuity , switch on and off, tester move forward and reverse meter means good plug/ if does not move the fuse of the unit is open.need to replace.
Dec 28, 2007 | Blueair Blue Air 402 Smokestop Particle...
Bionaire Hepa filter
The carbon filter should have the air passing through it first, before the hepa filter. The carbon filter removes the large particles which would otherwise block the hepa filter very quickly. Contact these guys if you need more help; http://www.bionaire.com/contactUs.aspx Hope this helps :)
Jan 01, 2007 | Bionaire LC0760 Air Purifier
Air Purifiers Logo
47 people viewed this question
Top Blueair Air Purifiers Experts
Are you a Blueair Air Purifier Expert? Answer questions, earn points and help others
