Question about Goodman CKL60AR60 Air Conditioner
I replaced the 60 amp breaker cause it kept tripping now the breaker doesn't trip anymore but the outside unit won't come on
    Genius:
  • Goodman Master
  • 1,363 Answers
If you were tripping a 60 amp breaker i would replace contactor that can burn contacts quick.
Posted on Aug 09, 2015
5 Suggested Answers
  • 1214 Answers
SOURCE: goodman heat pump trips sometimes no know cause.
20 AMP Circuit, huh? More on this below.
The tech probably didn't put a hard start kit on, but if he did, I hope he added the resistor to the start capacitor, or you could have a problem in the future. He probably put a soft start on it, a 2 wire device which looks like a capacitor. But only you will know for sure (or he.). As for warranty, manufacturers don't care about soft or hard start kits. In fact, they like 'em, because they extend the life of the compressor, which keeps them from having to pay for a new one.
I would be concerned with a 20 AMP circuit for anything higher than 2 tons. Take a look at the nameplate rating on the side of the condensor and tell me how many Running Load Amps (RLA) this unit is supposed to pull.
Also need to know your line voltage at the condensor, with the unit running.
Posted on Jan 28, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have 60 amp circuit breaker on my electrical a/c
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Posted on Dec 07, 2009
Testimonial: "Thank a lot this was very helpful"
  • 125 Answers
SOURCE: breaker tripping to a/c unit,
You have a high voltage short (most likely) or the breaker is bad.
Turn power off to outside unit and remove service panel.
Look for any arcing or burned wires. Look down in the unit as well for these signs.
If you have eliminated the breaker as the problem and do not see any of the above signs, then the fan motor or the compressor is going to be the problem. More than likely the compressor. This will require replacing the compressor to repair the problem.
Hope this helps.
Posted on Sep 20, 2011
  • 1033 Answers
SOURCE: My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Posted on Jun 11, 2012
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
Jun 10, 2012 | Goodman Heating & Cooling
15 amp cutler hammer branch feeder type AFCI triped off and will not turn back on. I have tried switching off for 10sec and then back on and still nothing. Also, the test button will not do anything. The...
if the breaker has tripped the test button won't do anything ,, for the breaker to trip something down stream of it is causing this to happen,, check all the switches and or receptacles in the circuit that are controlled by this breaker, 3 types of line problems cause tripping,, ground to line, Line to line, and line to neutral. in this ,, also consider that extension cords, faulty appliances , ( lamps, radios, anything plugged in with a feedback short ) will cause the breaker to trip. even a nail to hang a picture that pierced the wire can cause this, add to that , a AFCI breaker will trip much more easily than one thats not, or even a GFI breaker, , try this, if you have the knowledge to do electrical work in a panel, if not get someone who is, switch the tripping breaker with another one of the same value, ( in this case 15 amp) see if the one you put in place of the one thats giving you problems trips. If it doesn't, you have a weak or bad breaker, so just replace that one, if it does, your going to have to trace out that entire circuit to find the reason for the feed back into the panel
Oct 07, 2011 | Electrical Supplies
I "won" a Rainmate from
No, not that I'm aware of. But, the problem itself, may be in the electrical receptacle. A loose wire, a bad connection or interior damage could all cause the circuit breaker to trip. Or it may simply be the case, of line that air purifier is plugged into, is simply overloaded, because of other electrical appliances are on the same circuit of tripped the circuit breaker. Most air purifiers have their on circuit breaker or fuse built-in to the unit. And that, will usually trip before the circuit breaker in the breaker panel of your home.
Here's how you test that theory: Plug the unit into another outlet, that is on an entirely different circuit than the original one and turn it ON. If this trips a different circuit breaker, then you know it's an internal problem with the unit. If it doesn't trip the circuit breaker, the problem is with the original receptacle or the line that feeds that receptacle and it's circuit breaker.
Hope this helped you to troubleshoot and solve the problem.
Jun 13, 2011 | Rainbow Rainmate Air Purifier
Hello, my heat pump is a 4 ton unit, it heats ok but it keeps tripping one of the breakers, the 40 amp cooling breaker. I have put a new thermostate, it keeps running after the breaker is tripped and the...
Hello Jack,
Let me see if I have this right. Your heat pump keeps triping the breaker that is going to your airhandler. The Heatpump is on its on breaker and can not trip the breaker on your air-handler. However, the 40 amp breaker is to you heat pump its self (the outside unit). The thermstat is not the porblem as all it does is call for heat or cool. The problem can be one or a cobination of three things the contactor, the run capcitor or the breaker is weak.
The first thing I would do is replace the breaker as if it has tripped more than twice it needs to be replaced. Then I would look at the contactor, it is located underneath the service panel it will have some low voltage wires on the sides and a black and white wire running to it from the disconect box. If you notice the contacts are chared (little copper points in the middle of the contactor) I would replace it. If the contactor looks good I would remove the capcitor (carefully not to touch to contacts at once as they hold a charge) and take if to the local parts house and have it tested.
I hope that I have asnwered you question and you are able to take care of the problem. Thank you for using FIxya and do not hesitate to ask more questions.
Justin
Mar 09, 2011 | Ruud UBHC Air Conditioner
I have 60 amp circuit breaker on my electrical a/c heater with a 45 amp fuse. I had the unit for 7 years with no problem. This month the 60 amp circuit breaker keeps tripping when the heater goes off. The...
Shastalaker7
Dec 07, 2009 | Goodman CKL42AR42 Air Conditioner
My electric furnace keeps tripping the breaker , it will run for about five or ten minutes then trips.
If you dont have an ampmeter it is hard to tell whats going on. First check the breaker and see if it is getting hot. If so turn off power get a screwdriver and check to see if wire are tight on the breaker. Loose wires cause breakers to trip. If the unit has ran before and it has not tripped the breaker and it hss just now atarted replace breaker but do not put a larger one in. Check the size of your heat strip in Kw or what they call for on the size of the breaker. 10 kw no larger that 60 5kw no larger than 30. 15 kw has a 60 amp and a 30 amo circuit. Let me know whats going on.Rus
Dec 07, 2009 | Refrigerators
My house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Sep 11, 2007 | Heating & Cooling
Electrical - Air Conditioning
Ben, you are on the right track. To upgrade the breaker, first look at the main house breaker panel and determine if allowing more current through main breaker will be taxing it too highly (will 20 more amps exceed my main breaker limit...what is the main breaker current trip at?) Then look at the wire size leading away from the 40 amp breaker to outside. If it is 6 gage copper or 4 gage copper-clad aluminum wire, you are ok to upgrade. Any smaller wire size could be unhealthy.
Sep 03, 2007 | Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
