Question about Samsung Dryers
Samsung DV457G gas dryer convert to propane
I need to know how to open it up and how to convert to propane
ngafm
  • 166 Answers
SOURCE: Natural GAs to Propane
Call Maytag or whirlpool!
Whirlpool makes Maytag now same company
They make a conversion kit!
ngafm at your service.
Please rate me before you sign out!
Posted on Sep 06, 2008
aborcass
  • 2651 Answers
SOURCE: Converting natural gas dryer to propane.
yes youllneed to know the exact model of your dryer, then you can call the manufacture for a conversion kit. not going to be Available at hardware or plumbing supply,
Posted on Feb 27, 2009
  • 10865 Answers
SOURCE: dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
Posted on May 27, 2009
SOURCE: samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Posted on Jul 01, 2009
SOURCE: Convert Whirlpool dryer from propane to gas
I have a whirlpool dryer as propane and needed it converted to gas. I have the orifce -gas kit which consist of two parts. Which part do I use? Is it the one which screws in and mist hole is on the other end, or the other one it comes with that has the mist hole on the other side.
The one i placed was the later ( one with mist hole on the side)
Posted on Aug 02, 2009
Convert dryer to propane. We have the Whirlpool converter for Maytag dryer.
If this is natural gas dryer, you need a certified gas technician to do the work. You can't do it yourself as it is too dangerous. The gas air mixture and the gas pressure has to be set with a tool called a manometer.
If the dryer was electric, and you want to convert it to propane, that is impossible and can't be done.
Feb 07, 2017 | Whirlpool Dryers
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
How to remove the front cover of my samsung front load gas dryer
take the top off first by removing the two screws in the back, then the five screws which hold down the door section. the door will lift off and then follow the instructions
Jun 08, 2009 | Samsung DV448AGE Gas Dryer
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
You must purchase a conversion kit from your appliance parts store.
Mar 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Samsung gas dryer convert to propane
Mar 18, 2009 | Samsung DV448AGE Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
How to convert a drier from nat to propane gas i dont have the instruccions
NOT SURE BUT DON'T THINK YOU CAN USUALLY CAN GO FROM PROPANE TO NAT BUT I KNOW WITH FURNACES YOU CANNOT GO FROM NAT TO PROPANE AND THAT IS THE CASE WITH GAS LOGS AS WELL BUT NOT 100 % ABOUT DRYERS .
Dec 23, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
