Question about John Deere 3-point Hitch Kit A,b,g,50,60 & 70 Tractors
Air lock In 3 point how do I repair it - John Deere 3-point Hitch Kit A,b,g,50,60 & 70 Tractors
F22 flashing on hot point washing machine
Google it this is not the hotpoint website .
Jan 06, 2017 | Washing Machines
Door lock for Turbo AIR
How to remove the 3 locks from the panel. Both side of the panel are riveted. How to remove the panel to reach the 3 locks.
Jul 21, 2013 | Turbo Air Reach-In Refrigerator- 3...
Ignition key wont turn
the problem more than likely that the Tumblers have jammed and you need a Key Cylinder . at this point the repair is simple as long as the key will turn to the start position
if it won't then disassmbly of the Theft and lock sectors will have to be done - see your local Independent repair sh
Feb 01, 2013 | 2007 Chevrolet Chevrolet Aveo 5 LS
I have a 2 or 3 year old General Electric Air Conditoner 10,000 BTU. I used it for about 3 months and took it out cause it would come on and not come on. It had a mind of its own. I resently reinstalled it...
The key pad is shorted,damaged or loose solder point connection . You could try having it repaired, it's usually the solder points where the power connects to the board, or you could order a new one by calling in the model number to the manufacture. The other option is to replace the entire unit.
May 13, 2011 | GE AEW08LN Air Conditioner
How do i use the schwinn airdriver 1100 pump
This pump is a bit strange to use. The valve in the filler head is odd in that it controls the flow of air in both direction...which is not a great design in my opinion...but it does allow for use in different filling applications. The trick is getting the pump into its different filling "modes"
For a Schrader bike valve:
1. Make sure the pump is in "tire mode" by blowing into the valve with your mouth. If you then pump the handle you should feel air filling your mouth.
2. Put the "locking lever" in the unlocked position, the unlocked position is when the silver metal lever is parallel to the air hose, or said another way it makes an "L" with the air outlet that goes on the tire air filling stem. To verify this is correct, look in the air outlet and move the lever from locked to un-locked, you will see slight change in the diameter of the outlet.
3. Push the air filler hole over the schrader valve really hard and make sure it is seated all the way down. Close the "locking lever" (silver metal lever should now be perpendicular to the air house and be in line with the air outlet... i.e. point straight out away from the tire filler stem.
4. Pump.
For a Presta bike valve:
1. Make sure the pump is in "tire mode" again.
2. Take off plastic caps off presta valves on bike tire.
3. Unscrew the little nut on the presta stem to allow the tire valve to open when pressure is applied (you can test this by pushing the stem in a little and air should escape, the nut holds the valve closed, so it needs to be loosened).
4. Take the adapter from the locking lever (silver metal lever) on the pump and screw it on the presta valve. The adapter is the brass looking thing. Screw the rubber gasketed side down on the presta valve.
5. Press the air pump tire filler outlet onto the adapter.
6. Close the locking lever to seal the filler head on the adapter.
7. Pump.
8. Unlock the locking lever and pull it off quickly.
9. Unscrew the presta adapter and screw down the presta valve nut but just finger tight.
10. Screw on the plastic cover cap for the presta valve.
To Fill a Ball:
1. Twist the ball pin filler out by rotating the gray plastic tab around until the ball pin filler is pointing straight out (in-line with the air hose).
2. Make sure the pump is in "Ball mode" by again blowing into the filler. Sometimes shaking the filler valve really hard is necessary.
3. Put the filler pin into a ball.
4. Pump.
Hope this helps.
Apr 27, 2011 | Schwinn Cycling
Nokia N97 usb block has degraded to the point it wont charge unless balanced on an object. does anyone have a guide on how to replace the usb block connector and where i can get one? \r\n warrenty was...
well you will have to change the charging point and u can always do that at a phone repairs shop or take it to the company shop nearest to you for repairs and if you dont want to go tru that stree you can always charge your battery tru desktop charger , thnks .
Jun 15, 2010 | Nokia N97 Cell Phone
Locked seat belt elantra 2005 and cut off wire.
First correct the problem before any resetting is done.need to repair the wire (check wire color).disconnect one battery terminal first before anything else.If wire is broken form the connector pin using pointed stiff wire pry off the pin lock up(plastic lock ussually diff color from the connector)pull it off completely and from inside the connector u can see a tiny lock each and every pins.use the pointed wire lift slightly the lock and pull or push the pin out.use solder to join the pin and wire.you may need a diagnostic computer to reset the mil light (malfunction indicator light)
Jan 16, 2010 | 2005 Hyundai Elantra
A/C Vents
cable lock mechanism on air diverter plate is broken.probably at control panel rear arm point. haynes manuel at auto parts store shows repair procedures.
May 09, 2009 | 2001 Chevrolet Astro
Copper contact points broken
There is a repair outfit located through the internet that seems reasonable for approaching for a more involved repair job. Contacting them may get you the parts you require.
The one I looked up had rebuilds available, so you might be able to get a replacement for a better price with your old one exchanged.
If you go this route, just do a web search for Ecoquest air purifier parts/repair
Jan 17, 2008 | Ecoquest Fresh Air Air Purifier
John Deere 3-point Hitch Kit  A,b,g,50,60 & 70 Tractors Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
