Question about Casio Watches
Casio SGW100 resets itself
I received the watch about a couple of weeks ago as a prize in a raffle. It has since reset itself at least twice to 12 o'clock on January 1st. What causes this? Am I hitting a couple of buttons at the same time and not realizing it. battery seems good as the light works fine.
  • 8 Answers
SOURCE: PRG-70YT-1V self-reset
no, it changed automatically via the atomic satellite that changes all atomic clocks around the world. It so happens you bought a watch that was made in a different, much different time zone. You have been taken.
Posted on Jan 02, 2008
SOURCE: light button causes the time to reset, why?
Your battery is low and needs to be replaced, the light uses much more power than it takes to run the display
Posted on May 26, 2009
  • 183 Answers
SOURCE: Suunto watch keeps resetting itself. Changed
You wouldnt think a whole lot could go wrong with a Suunto battery change. If they had trouble getting the coin access back off and unscrewed the case then the button contacts might be out of line causing your problem. You might also check to be sure that they put the right battery in and that there are no pry marks as sometimes there are problems getting the battery out. If any excessive pressure was placed on the circuit board and it cracked it will need to be replaced.
Posted on Sep 22, 2009
escapement
  • 2334 Answers
SOURCE: Casio tough solar databank Model DB-E30-1AV
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Casio watch manuals. Rate me, plz.
Posted on Feb 23, 2010
  • 15 Answers
SOURCE: Can't receive atomic signal
You can get it serviced at www.casiosalesandservice.com or call them toll free 877.659.0761
My g shock ga 100 keeps resetting itself back to 12:00 and the analog doesn't stay synced to the digital i have had a new battery fitted and it still doesn't work any suggestions ??
Did you take your Casio to a pro or it was just a normal battery replacement service?.
I am asking because if a pro did it seems he forgot to reset your Casio watch when battery was replaced.
This is a must when you change battery on a Casio digital watch.
Take it again and ask for a complete reset, if they know what they are doing they will do as you ask without questioning.
Casio Watches
Jul 02, 2014 | Watches
I have a Casio Wave Captor 4757 WVQ-142E and after the change in time this fall I can't seem to set the time correctly. I am in Paris, so GMT +1, however it is 10:30 and my watch reads 3:03. I have reset...
I sympathize, it took me ages to work this out - I had the same problem having had the battery replaced in my watch which only lasted 18 months...the irony was that my previous watch was still working & set to the correct, time date etc!
The following instructions are for the Casio Wave Ceptor 4757 WVQ-142E, the official Casio instructions are available at the following:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4757
For the extra information Casio neglect to tell you in the manual, read the following:
First, the watch needs resetting. To do this you need a watchmaker's screwdriver, remove the back (4 screws - obviously, you do this at your own risk), remove the thin plastic cover to reveal the battery.
On my watch on the battery cover it says to reset the watch, get a pair of tweezers & connect the battery back to the negative (marked -) plate for about 2 seconds, thus forming a circuit.
The watch stops, the screen goes blank for about 30 seconds, replace the plastic cover , back & screws.
Wait until the watch has picked up the correct time signal, the digital part will show the correct local time, the analogue screen won't at this stage.
Set the watch to the desired time zone that you require or HS (Home Setting).
Then press button "C" (bottom left) to scroll through until "HS" is displayed on the screen, then press button B (top right) for about 5 seconds until it flashes "OO" in the screen, then press the A (top left) button down & to reset the analogue time (so all 3 hands are pointing up) to 12 O'clock, it has to be set to 12 so the watch will recalibrate itself, if it is not set to 12 O'clock, it won't work! - sadly Casio don't tell you this bit in the manual....& of course this is really obvious to us mere mortals!
Now that you have aching hands & repetitive strain injury, press the B button (top left) to exit the (watch) hand setting mode & the watch will now wind the hands by itself to the correct analogue time, (or in theory it will, it took three attempts to set my watch).
Yes, for the record Mr Casio, if you hand a watch to someone & tell them to set it to the correct time, they will set it to the current local time (assuming that it is not 12 O'clock) & as opposed to 12 O'clock by default!
This is not rocket science, if your company is able to make & market a radio controlled watch which is in theory accurate to one second in a million years because it is controlled by the Rugby atomic clock, you'd think that the instruction department could write some decent instructions!
Hopefully this solved the problem!
Nov 02, 2010 | Watches
My Casio Wave Ceptor 3054 has started resetting to 12:00, 1/1/05 at random times. Why?
My Wave Ceptor also reset to 01/01/05 four days ago. I've had it for more than a year and this is the first time it's happened. It hasn't reset with automatic updates and I can't get it to manually update.
Aug 21, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
The digital display shows the correct time but the hands do not.
hi there when you replace batteries in wave ceptors all hands have to be set to the home position (straight up at 12 oclock), as the instructions vary wildly from watch to watch you will have to download the manual from www.casio.co.uk you will need to put in the module number (found on the back plate of the watch), this will be in PDF format, you can download adobe reader for free from www.adobe.com to read PDF files. good luck
Aug 20, 2009 | Casio WVA105HDA Wave Ceptor watch
Reset itslelf. WIll not display correct time, day, or year
My Casio wave ceptor keep resetting itself like this when the bottom right (D button) is pressed. I need to make sure I reset the city code or before trying to receive as it defaults to Tokyo. Press & hold the top left (A button) and date changes to city code. Scrole through codes using right bottons.
Hope this helps.
Nick
May 29, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Reset the time on my Casio GW300
When out of broadcast range for a time signal, the online manual procedure works for me: http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2608&submit.x=39&submit.y=11
Jan 03, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Day of week no longer shows up
Needs a new battery or pitch it and buy a new one. Not really a repair but a replacement job.
Nov 12, 2008 | Casio Baby-G BG370S-4V Wrist Watch
Jun 03, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
