Where can i get a coy for a ruud air conditioner model UHSA HM4821JA
  • 54 Answers
SOURCE: ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
Posted on May 30, 2008
  • 20 Answers
SOURCE: Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Posted on Jul 23, 2008
  • 182 Answers
SOURCE: ruud air conditioner model uamc 060 jaz
check breakers first,then fuses in disconnect if applicable,then capacitor.
Posted on Aug 18, 2008
  • 340 Answers
SOURCE: How can I validate the tonage of my Ruud air
you must have very old equipment are you sure of the model and serial number it might be a 69 if the serial number is the m0696. Tom double check those numbers.
Posted on Jun 28, 2009
pilungu
  • 30 Answers
SOURCE: Air Conditioner (RUUD model: UBHC-14J06NFD) is
1) you probably have a clogged drain line and
2) your air handler coil may be dirt.
Solutions:
1) Using a dry/wet vacuum cleaner, attach it to the drain line outside and **** all the gunk out of a drain line; or using a water hose, attach it to from inside right by the air handler and push the gunk out with the force of water - be careful using this method. Or simply pour draino into the air handler pan, wait for 10 minutes and using a cup pour water in the pan to see if it drains fine.
2) if the coil is dirt and it ices up, call a technician to for coil cleaning.
Posted on Oct 12, 2009
Fan not running
Check the fan's run capacitor.
Nov 26, 2013 | Ruud UHSA-HM1817AA 1.5 TON AC/HP FAN COIL
My ruud achiever series model UHSA-HM2417JA is blowing out cool air even when turned on to heat. we replaced a fuse yesterday but no luck. help!
hi manda,
i think its a heater problem..if you can check the heater..its better!
http://www.2instructions.com/search.php?cmarque=RUUD&modele=UHSA-HM2417JA..
try downloading the manual here..
mastergani
Jan 07, 2011 | Heating & Cooling
I have a Ruud AC DATE: 12/00 Model:
Here is a tip about trouble shooting your air conditioner...
I would check the air filter and the blower motor...
sounds like a problen with one of them...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 20, 2010 | Ruud Heating & Cooling
Looking for a manual for RUUD model number 92212650402
Hi, you can get a manual from your local Ruud, Rheem wholesale parts house. If not, go online and you should be able to down load one. Just have the model, serial, and product number if there is one handy.
Good Luck, Shastalaker7
Nov 03, 2009 | Ruud UBHC Air Conditioner
The Ruud breaker (60amp) with a integrated pigtail is not delivering the correct voltage to the lower part of the handler. This breaker is part of the heater insert inside a UHSA-HM3617JA I want to get...
The breaker in the unit is for the heat strip.Are you trying to heat?If so It should give you 240v from it.I know those breakers are pretty cheap and home depot,and usually cheaper than calling a a/c tech.Good luck
Aug 06, 2009 | Heating & Cooling
Jul 03, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
