Question about Texas Instruments TI-Nspire CX CAS Handheld Color Graphing Calculator with Computer Algebra System
Trying to convert C to degree F
I need to know how to get my ti nspire cx cas to covert 1910 degrees C to degrees F. Also how do i Format a problem to covert moles or convert anything. i know i can open up catalog but i don"t know exactly what way to input in in my calculator to get the answer. EX) Convert 10cm^3 to m^3
    Sergeant:
  • Texas Instru... Expert
  • 264 Answers
See captured image below
trying to convert C to degree F - trying-convert-c-degree-f-fx4uccky3tacrxnvblcaha0c-1-1.jpg
Posted on Oct 10, 2015
3 Suggested Answers
  • 1833 Answers
SOURCE: my TI-nspire isn't graphing correctly.
According to your problem, first check the battery status or replace the battery. It may occur for battery. You need a software and firmware update for this calculator. Reinstallation of software and an update of firmware will solve your problem.
Posted on Jun 16, 2011
  • 7993 Answers
SOURCE: how to change between a degree mode and rad mode using the Ti-nspire CAS
  1. Turn calculator ON
  2. Press 5:Settings> 2:settings>1:General.
  3. The second line reads ANGLE.
  4. Use the right arrow to open the submenu.
  5. Select the unit you want.
Make sure you validate the changes you make by using the arrows to highlight the OK button at the bottom.
Posted on May 13, 2012
When graphing in documents my TI nspire cas cx is stuck in relation mode instead of function. How do I reset this?
How about starting a new document, or adding a new page, or just turning the machine off without saving?
Sep 24, 2016 | Texas Instruments TI-Nspire CX CAS...
I need to find how to insert polar phasor to convert to rectangular complex...
See captured image below. These examples are computed for angles measurement in radians and degrees in two dimensions
Jan 29, 2016 | Texas Instruments TI-Nspire CX CAS...
Ti-nspire cx CAS gives answer in degrees even though it is in radians mode.
When you set some configuration parameter you must scroll down the setup until you reach the OK button. Press the OK button to validate.
Oct 09, 2014 | Texas Instruments TI-Nspire CX CAS...
TI-nspire cx changing from degrees to radians
Press Documents Settings. On line angle select radians, AND validate the change by moving the cursor on the OK button, and pressing it.
Jun 12, 2014 | Texas Instruments TI-Nspire CX CAS...
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
restarts.
unit.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
Hi, when I'm solving a trignometry exercise, using both degree and radian my Ti Nspire CX (not CAS) will only provide something like a aproximated number instead of giving me the answer in square roots or...
I am afraid you cannot do that. The CX has only two calculation modes AUTO and Approximate, while the CX CAS has these modes and a third one EXACT. That is the one that allows display of result with square roots and the symbol of Pi. Your best choice with the CX is to set the calculation mode to AUTO.
Oct 06, 2013 | Office Equipment & Supplies
How to get the ti nspire cx to give square root answers
You can not achieve this with the Ti-nspire cx. Only the CAS version will give the square root form. On the CAS there is an option in the settings called "EXACT" under calculation mode. The cx does not have this mode.
Jan 09, 2013 | Texas Instruments TI-Nspire Graphic...
My ti nspire cx cas is totally stuck at the loading screen , it keeps reloading and reloading with a sign at the left corner at the bottom that say's that my battery is empty ? what should i do ?
I have a doubt, when I choose to completely format the calculator it will clear your operating system, files saved on it, but the product key (ID protuto) will be deleted too?32d3cd84-9b87-4f5d-abfe-aa04ca86df4c.jpg
Dec 18, 2012 | Texas Instruments TI-Nspire CX CAS...
Texas Instruments TI-Nspire CX CAS Handheld Color Graphing Calculator with Computer Algebra System Logo
109 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
