Question about St. Bernard Software iPrism M1200 Firewall
I need i prisim unblocked - St. Bernard Software iPrism M1200 Firewall
I have a T-Mobile prisim HB5K1K how do I jailbreak it?
Try this:
Settings > General > Reset > Reset Network Settings.
Jul 30, 2013 | Cell Phones
Dropped unit. Knocked the prisims loose. All
It's quite easy to dismantle and inspect, look for tiny retainer screws around eyepiece and/or unscrew lens shrouds. Normally the prisms shouldn't come loose in average to good quality viewers, they'd be held in by some sort of retainer, eg- flexed, spring tempered metal, where you screw in one side and then have to flex (bend) the metal to screw in other side over the back of the prism. It sounds like yours may use an adhesive retainer, if so clean of old residue and use fresh silicone, or may have broken the clip and or screws. But it may just have popped out, in which case reattach it. Make sure the prisms are seated properly, 1 hardly visible flake of glue or dirt under the prism will offset vision noticeably. I would say you may be lucky and find an honest repairer for about $45.00 if prisms aren't damaged.
Dec 11, 2009 | Swift 779 Birdfeeder (10x40) Monocular
Specifically, what do I need to do to fix double vision in my 10-x25 Cabela's wide angle binos? I believe they were dropped.
If they are expensive binocs I would take them to a camera shop for a repair estimate. If they are somewhat inexpensive I would just replace them. They might be bent or the prisim damaged or an internal lens that has came loose.
Sorry, wish the news was better.
Bob
Oct 24, 2009 | Nikon Action Binocular
Help!
My guess is that the prisim broken or led (light emitting diode) below it has failed so the vcr is stuck in an endless load...
It will have to be taken apart and the tape in it manually unloaded by turning the load motor counter clockwise. Then visually inspect the prisim and test the diode.
If any of this sounds too foreign take it to a good shop and they'll have it back and running in no time..
Hope this helps!
Bill
Nov 14, 2007 | Philips CCC132AT 13 in. TV/VCR Combo
TV keeps shutting off after 10 seconds
It's possible from what you described that your center LED or prisim was broken when the tape was extracted. Like many others these units depend on a series of startup checks and one being the tape path. On the play table of the VCR is a center prisim/LED and two light sensitive diodes on either side of the tape loading assembly. If these diodes do not detect the infared beam the unit will go into shutdown. I'd check there and let me know. Bill
Jun 03, 2007 | Sylvania 6319CC 19 in. TV/VCR Combo
St. Bernard Software iPrism M1200 Firewall Logo
Top St. Bernard Software Computers & Internet Experts
David Payne
David Payne
Are you a St. Bernard Software Computer and Internet Expert? Answer questions, earn points and help others
