Question about HP - HP Photosmart 8250 printer
How to make usb printer a network printer - HP - HP Photosmart 8250 printer
Can i make a hp2420d a network printer
You can purchase a jetdirect network card from Ebay. Any model will work, a 610 should not be too expensive these days. Or you can purchase a USB network print server and connect the printer to the USB port on the printer and then connect the print server to your network.
Aug 10, 2014 | HP Office Equipment & Supplies
Tip
How to use scaner, camera, printer (any USB device) remotely
We use USB devices every day: MDF's, scanners, webcams, printers, etc. Not all devices you usually use at home can be redirected over the network to other work places. Sometimes your family members may need to use these devices on different computers. Of course, carrying devices back and forth the house is not the best solution:)
You can avoid this headache if you have apropriate software solution on hand. USB Network Gate, one of such software solutions.
USB Network Gate is an essential USB sharing solution that allows sharing USB devices over network or Internet. In other words, Network USB Gate allows using USB devices on a remote computers or virtual machines as if they were connected to it directly. You can also share USB devices over RDP.
USB Network Gate offers much more options and possibilities. Navigate to this website for details USB NETWORK GATE
on Jun 25, 2015 | Miscellaneous
Hello , I need to know if hp-laserjet p2015 printer have a "built in" network card ? if not how can i share it between two computer by using a switch ?
HP Laser jet P2015n & P2015dn models having network facility, there is no option to add on network card for this series.
1. Install the printer locally through USB in one system and share it to others if its non "N" printer.
2. You can connect use network to USB convertor to print thorugh network. pl see the link for one of the sample product..
http://uk.shopping.com/Conrad-USB-2-0-NETWORK-ADAPTER/info
Sep 20, 2011 | HP LaserJet P2015 Printer
Hi i have the canon mp490 all in one printer and i was just wondering how to i get things to print from my lap top
1) Install the network adapter on the printer, if necessary. Many wireless printers have the adapter pre-installed, but if this isn't the case, turn off and unplug the printer. Then, remove the back cover on the adapter slot and place the adapter into the slot.
2) Plug in and turn on the printer. Then, insert the drivers CD that came with the printer into the CD drive of the computer. If you've misplaced the CD, the drivers can be downloaded from the website of the printer's manufacturer.
3) Configure the network adapter. Once the drivers installation has loaded, select "Using a wireless network" and then select "Next". Usually, there is a User Agreement at this point, to which you will agree and press "Next".
4) Connect the laptop to the printer using a USB cable. Connect one end into the USB port on the back of the printer and the other end to a free USB port on the computer.
5) Finish configuring the network adapter. After connecting the laptop and printer with the USB cable, select "Create or modify the printer's wireless settings" and then click "Next".
6) Connect the printer to a wireless network. The wireless setup utility will automatically open after the adapter has been configured. Find your wireless network in the "Wireless networks found in your area" and select "Next". Then verify this information on the next screen.
7) Connect the laptop to the printer through the wireless network. Now, disconnect the USB cable. Make sure that both the laptop and printer are connected to your network. If they are, you're now set up.
Aug 05, 2011 | Computers & Internet
Does hp laserjet 5200 have netword printer
Here is your network guide for the 5200n printer
If you do not have the 5200n printer, it is not network. You will need a 'print server' ($100 approx). Get USB or Parallel, depending on the connection it uses.
Mar 30, 2010 | HP Hewlett Packard LaserJet 5200 Printer
TEST PAGE REFUSE TO PRINT ON MY HP LASERJET P2015DN PRINTER
It's a network printer. Are you connected via the network or USB? If you run the CD wizard and select the wrong option it will not print.
In either case, insert the CD, and select the proper method of connection (USB or network), it should see the printer, if it does not you have a problem, so check your cable connection (either rectangle thingy - USB, or Network - big phone jack). From there, make sure (especially in network mode) that the printer is configured properly.
Dec 28, 2009 | HP LaserJet P2015dn Printer
The printer doesn't print any of the jobs that i give it over the network. All the pc's on the network can see the printer but they can't print
I know it sounds silly but make sure you are trying to print to the network printer and not the USB printer. If you installed it as a USB printer and then again as a network printer there should be two. I know it sounds silly but make sure you are trying to print to the network printer and not the USB printer. If you installed it as a USB printer and then again as a network printer there should be two.
Nov 23, 2009 | Brother MFC-9420CN All-In-One Laser...
Printer model HP color 2605dn does not print from PC
its a communcations problem, make sure the USB or network cable are attached to usb cable computer, network cable to wall jack or hub.
it can also be a driver issue.
is the printer connected via network or usb?
Nov 21, 2008 | HP Office Equipment & Supplies
Wireless printer
HP PSC 1410 is neither a Wireless nor a Bluetooth printer.This printer will not support to any network application, but HP PSC 2410 supports.So do not confuse between 1410 and 2410.If you want this printer to be shared in the home network, then thats possible.Also if u have print server that supports USB printer we can achieve connecting this printer in the network.
Do u have any other PC that is connected to the same Home Network?
Please let me Know.
Thanks
Riz.
Apr 17, 2008 | HP PSC 1410 All-In-One InkJet Printer
12 people viewed this question
Seeker5211
Seeker5211
