Question about Trek 7.5 FX
Having trouble reattaching the front brake
We disconnected front brake and now can't get it back on
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: How do you put the front wheel back o? How do you
Run those questions almost verbatim through any search engine and you will find videos.
Posted on Jul 15, 2011
How to bleed the clutch on a 2002 hyundai accent
its the same process as bleeding brakes- except you pump the clutch pedal and loosen the clutch slave cylinder located by the front motor mount instead of a brake slave cylinder.
what i do is just loosen the slave cylinder bleeder screw and let it all run dry. then disconnect the reservoir from the master cylinder and clean it out with brake cleaner because all that black junk rests in the bottom of that. theres still more in the line, so reattach the reservoir and fill it up. let it bleed all the way back down the line and proceed to pump and bleed the system. if you know how to bleed brakes it should be a piece of cake.
Aug 13, 2016 | 2002 Hyundai Accent
Trouble compressing rear brake cylinder on 1992 Buick Regal
does the caliper piston have any notches cut into the edge of the top of it? if so you need a special tool to rotate that back into the caliper
Jan 18, 2018 | Buick Regal Cars & Trucks
Jul 14, 2011 | Trek 7.5 FX
Just today had brake booster replaced. Arriving home after dark, brake lights would not turn off! Tried removing fuses-etc. - nothing works. Help! Battery will drain overnight. Thank you!
Your brake light switch is stuck. It's mounted just under dash above your brake pedal. Sounds like it wasn't adjusted properly. You can disconnect your battery for the night and reattach in AM to get back to repair shop for proper fix. Remember when reattaching cables, NEGATIVE CABLE GOES ON LAST
Jan 18, 2011 | Plymouth Voyager Cars & Trucks
Having trouble changing front brakes need some help
w/tire off insert strt screw driver into middle hole on caliper pry back towards you this will retract caliper, in rear of caliper 2 bolts pull those bolts remove caliper @ install new pads,, NO BLEED BRAKE REPLACEMENT, make sure to apply anti squeal lube to brake pads..pump brakes up after installation before driving!!! hope this helps!!!!!
Aug 16, 2010 | 1989 Isuzu Pickup 2WD
How do i fix the brakeline on my 1994 honda accord with a v4 engine?
The brake line will run from the back of the wheel backing plate to a connection point further toward the front or center of the car (where it connects, along with the other brake line) to a fitting. The line can be removed and replaced. Patching it would be a waste of time because a brake line, when the brake pedal is pressed, undergoes a great deal of hydraulic pressure. The lines are specially made to withstand that pressure. If you were to undertake the job yourself, you should take into account that it can be a pretty dirty job since brake fluid is going to be flowing from the fittings once you disconnect them (you should be prepared to plug them so you don’t lose all your fluid) and the fittings are often difficult to turn with a wrench The following is the procedure, but I would seriously consider finding a local garage for an estimate for the work.
Disconnect the negative battery cable.
Elevate and safely support that side of the car.
Remove the wheel so it is easier to access the backing plate.
Clean the joint where the brake line connects to the back of the plate.
Place a pan under the joint to be disconnected.
Using two wrenches (one to hold the joint and one to turn the fitting) disconnect the line to be replaced.
Disconnect the other end of the line, moving the drain pan as necessary.
Disconnect and retaining clips or brackets that may be holding the line and remove the line.
If you are going to have the system open for more time than it takes to swap lines, plug the line coming from the main cylinder (toward the front of the car).
Install the new line, assuring yourself that both ends are correctly threaded and turn smoothly using finger pressure as you start them (consider that some lines are flexible hoses with fittings on the ends and others are solid pipe that has to be gently bent into the proper configuration).
Using the two wrenches, tighten each fitting to 9-12 lbs, which you can estimate. Good and tight.
Reinstall the clips or brackets you may have removed.
Refill the brake reservoir with clean, fresh brake fluid.
BLEED THE BRAKE SYSTEM.(that means all four brakes at the wheel bleeders, which can be a job in itself)
Replace the wheel, reattach the neg. cable, etc.
I hope this helps you.
Oct 19, 2009 | Honda Accord Cars & Trucks
2004 Pontiac GA brakes going back once a month
Sounds like the master cylinder isn't releasing pressure after you remove your foot... Usually the calipers hang up, but you replaced them so...replace the master cylinder and bleed the brakes
Mar 27, 2009 | 2004 Pontiac Grand Am
No brakes after changing brake caliper & bleeding system
Sounds like you still have air in your brake lines. Make sure all your brake lines are tight. Then bleed again. Bleed the trouble side first, meaning right side, then go to front left, back left then back right, make sure that your brake fluid is also full
Feb 11, 2009 | 2004 Toyota Tacoma
Brake pad replacement problems
get haynes repair manual.dont cost much .it got pictures .and it show you step by step .to change front disc brakes.
Jan 16, 2009 | 1999 Kia Sportage
Replacing front calipers
It is usually easier to disconnect the flexible brake hoses where they join up to the solid ones first then you can remove them from the caliper end without getting them twisted.
Oct 19, 2008 | 1988 Volvo 740
Trek 7.5 FX Logo
Top Trek Cycling Experts
Andrew Crawshaw
Level 1 Expert
dante
Are you a Trek Cycling Expert? Answer questions, earn points and help others
