SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
SOURCE: Sony KDF-E50A10
If the lamp is new it could be the ballast the one is supply high voltage for the lamp you can order that ballast from Sony
Check the lamp if is not damage any where
Cheers
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
SOURCE: Sony KDF E50A10 tv starts up but then shuts down
most likely power supply fault buddy/get part no search google
SOURCE: tv turns itself off after 2 minutes. the power
Hi...
Main power supply is overheating. Try getting it dusted out first then check into getting it serviced
