Question about Olympus SuperZoom 115 QD 35mm Point and Shoot Camera
I have and n2 fault code showing on my display
I had a problem when my camere stopped halfway through a film and now when i turn it on it will not do anything but the code n2 shows up on the display
  • risbeivok
    risbeivok Jun 17, 2012
    I had the n2 code showing after - by falling on the floor - the lens protection lid had gotten stuck. Snapping it back to its right track solved the problem.
  • 3 Answers
I think you're losing power. Try flipping out the battery.
Posted on Feb 20, 2009
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Canon MX328
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
error 5100 :
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
Apr 24, 2010 | Office Equipment & Supplies
Fault light flashing,
Is it please possible for you to add additional comments in your query about dishwasher problem
1. make and model number of dishwasher
2. are there any fault codes or lights showing up - which ones
3. at what cycle does the operation stop - eg still washing and there is water in dishwasher - is it warm/ cold, rinse is starting (can hear the pump) but stops halfway, rinse is complete but does not dry..
4. how old is the unit
clarification on above will help understand the problem better.
Jan 03, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Jul 13, 2009 | Samsung S860 Digital Camera
Pioneer n2
I think the problem is when created your mp3 disc it was not encoded with texts. Because all of the one I serviced did show the encoded infos(artists or titles...ect). Try to play it on another player see if it show up if not then you know for sure it is not your N2's fault. Goodluck.
Oct 02, 2008 | Pioneer AVIC-N2 Car DVD Player
Leica m2 film advance lever is stuck
mandie22,
on this model two strokes are needed to fully advance the film and to set the counter to the next #,
so advance the lever, bring it back and advance again.
Jun 03, 2008 | Photography
Blank film
I had the same problem. I think I finally figured it out. My problem was that the Shutter was in lock mode. In the manual book there is a section called "Shutter Lock." How to get it unlocked: While pressing the drive mode button (1), turn the camer on with the function dial (2); the data panel displays the status of the shutter lock. If it says "lock", you will need to do this process again to get it unlocked.
To find out where the buttons are, you will need to look in your manual -- page 53.
Hope this corrects your problem.
Nov 26, 2007 | Konica Minolta Maxxum 50 QD with 28-100...
Problems with camera display on kodak APS (something or other......)
I am having exactly the same problem (I have a T550). On the last film I shot, the only way to advance the film was to pull the battery out and re-insert it every time. When I printed that film, all the frames are blank! Kodak's FAQ about "clearing the logic" suggests a solution for that problem. 1. Turn camera off 2. Pull battery out 3. Turn camera on 4. Click the shutter approximately 6 times 5. Turn camer off 6. Repeat step 4 7. Reinstall battery I just tried that but the problem persists. I am now going to leave the battery out for several hours; maybe this will help. Otherwise, well it is time to bite the bullet and buy a digital !
Jun 21, 2007 | Kodak Advantix T550 Auto Focus APS Point...
Olympus SuperZoom 115 QD 35mm Point and Shoot Camera Logo
119 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
