Question about GE GFWN1100LWW Washer
Washer stops several times mid cycle requiring to push the start button, then extra spin cycle is needed
JULIANFIX
  • 975 Answers
SOURCE: GE Washer stops during cycle
CHECK THE SENSOR SWITCH underneath the washer where the door closes , it could be loose or damaged, hope this helps AJ
Posted on May 09, 2008
SOURCE: washer stops and start button blinks
The solution is pretty simple. there is a filter located right before the water pump.
* Remove the lower panel (lower as if you were looking at the front of the machine)
* Remove the 3 screws (it is easy if you have the lower drawer unit .. you will have to 'get low' if you don;t have it)
* You will see a 3" cap right facing you (in the center)
* GET A POT. and place it below the cap (foul water will come out when you remove the cap)
* remove the cap (finger tight)
* I found coins, hair, lint, dollar bills .. etc (about the size of a roll of cookie dough)
* Take CLEAN water and dump it into the washing machine (this will clean out the tube/hose)
* replace cap
* run machine BEFORE you put the cover back on (make sure it doesn;t leak)
* replace cover/screws
Posted on Jul 09, 2008
SOURCE: Washer pauses during spin cycle
Check the filter. I have the same problem and I found an string (slip) in the filter. The filter is back of the front pannel (under the door).
Posted on Oct 02, 2008
  • 77 Answers
SOURCE: GE washer - Top loader wont spin, clicks
main board problem
Posted on Apr 26, 2009
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
GE GFWN1100LWW Washer Logo
79 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
