Question about Hardware & Accessories
Rainmaster timer rm1100 setting up - Hardware & Accessories
I need the defalt possword for napco dvr
Configuration Information and Recommendations
If you purchased a workstation or server from Salient Systems please follow the following configuration information and recommendations.
Please note that the software registration key is attached to the USB port on the back of the system, if this is removed it voids the license of the software.
Windows Default Passwords Windows 7(S500, T3500, RM1000, RM1100, RM2000, RM2500/2800 w/analog boards)
Username Administrator
Password completeview
Windows 2008 Server Web Edition (RM2500/2800/3000 Server)
Password Completeview! (Case Sensitive)
PASSWORD Recommendations
# We recommend that you change the administrator password from the default settings.
# It is recommended to create a secondary administrator account, so that if your Administrator password gets reset you have a way of logging into Windows.
CompleteView (Client & Server Configuration) Default Passwords
Username admin
Password blank no password
Jan 20, 2017 | The Computers & Internet
Rainmaster modular 618 reticulation
hi how much do you want for your waterblaster
Dec 11, 2013 | Garden
We have just installed a rainmaster tap timer RM1100 and have lost the instructions
C curved arrow button ( middle left ) SELECTS TIME, DURATION, DAYS, START & also SAVES SETTINGS
RIGHT ARROW button ( MIDDLE RIGHT ) SELECTS Day or hours or minutes to be changed
MINUS button ( top left ) changes backwards values of: days, hours, minutes
PLUS button ( top right ) changes forwards values of: days, hours, minutes
HAND button ( bottom ) manual turn on & turn off water flow through timer.
Aug 05, 2013 | Motorcycles
Jet boat SL2000 bilge pump location how to access it
the tray that houses the cleanout plugs needs to be removed and pry'd up. thr pump is straight down from there.
Sep 08, 2012 | Rule Mate Fully Automated Bilge Pumps...
Pump won't stop running
It has an inbuilt float switch that may be sticking. Pull it out and tap it this may fix it. If not it will have to be replaced. Regards Phil
Apr 12, 2011 | Rule Mate Fully Automated Bilge Pumps...
How do you set the timer
You posted under Woods outdoor timer:
See this timer and other similar types to identify your timer for sure
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
If this is not your timer, look at other timers on the page and then add a comment, and I will post instructions for another timer.
Generally this type of timer each set the same way:
Instructions:
Timer tuns ON automatically at dusk
Use dial to set 4 possible options:
Set dial to Off , the timer is always OFF
Set dial to ON, the timer is always ON
Set dial to Dusk-Dawn, the timer is ON at dusk, OFF at dawn
Set dial to 2,4,6,8 hours, the timer is ON at dusk, lights OFF 2,4,6,8 hours later
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 23, 2010 | Woods Outdoor Lighting Timer
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
Rainmaster easy pro manual
800-777-1477 is a support phone number for Irritrol whose site contains Rainmaster information. I can't locate any info on "easy pro"
Dec 09, 2010 | Garden
I have a rainmaster rainman reticulation system.
Look at the wires on station 3 make sure it is not connected to the other station some times when installing the timer people get the common wire crossed with the same station and it will activate other station as well. Simply put i believe your wires are together.
Dec 20, 2009 | Garden
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
