Question about Sony Televison & Video
Sony 57 inch wide screen tv, model kp 51w5s510 projection tv repair
  • 59 Answers
SOURCE: sony rear projection tv
Bad green crt, this set has a problem with bad crt's
Posted on Oct 23, 2007
  • 4234 Answers
SOURCE: Sony 57" projection TV - need replacement screen
The part number for the screen for the KP57WS500 does not match the one for the KDP-57WS550. The inner screen is still available for the KDP using part number 4-095-924-01 for $120.32
Hope this helps,
Dan
Posted on Mar 24, 2009
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
welcomejee
  • 10594 Answers
SOURCE: my sony projection tv has bouble image. can i
Well repair of TV depends on your own skills and if you have any experience of electronics stuff repair then it would not be difficult. This kind of repair requires good parts soldering in PCB expertise.
Your Sony KP-51HW40 seems have problem with convergence out ICs (two ICs) that would be replaced. Both ICs STK392-560 are located on D Board and available in Part Store.
Thanks.
Posted on Aug 21, 2009
raklein62
  • 360 Answers
SOURCE: tv wont come on and a red light is blinking
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Posted on Oct 25, 2009
My sony wide screen projection tv comes on then goes red and blanks out.
If it comes on for under 5 seconds then it may be shot, if it comes on longer it may be the cooling fan is not working and may be an easy repair check with local tv technician.
May 21, 2010 | Sony KP-57WS500 57" Rear Projection...
The screen on my Sony wide projection tv is turning blue after a few minutes. can you help? the model # is KP-57WS500
This is a typical bad CRT. The blue CRT part number is 8-733-647-25 but they are no longer available. It is not uncommon for this eventually to happen to the other CRT's as well. The only fix is to have a technician pull the defective CRT and have it sent to a company called VDC for rebuilding.
Nov 11, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony wide screen projection tv model kp-57wv600 problem. Sound with no picture. Stanby red light blinks seven times? What parts do I need to repair the problem. Thanks ,Gary
I hope this helps.
Jul 19, 2009 | Sony KP-57WV600 57" Rear Projection...
Hope this helps,
Dan
Mar 23, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony 57 inch tube tv
when you get the pop does the screen change color?
Mar 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony rear projection tv
Oct 13, 2007 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
