Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Oven Shut Down
Oven operating at 220 degrees celcius just shut down and now there is no power to the display and it will not operate.
It has been 4hrs and the oven has not restarted.
Can you suggest the problem and solution
  • 4,889 Answers
Check for a blown fuse or tripped circuit breaker...It is most likely the fuse..
Posted on Oct 26, 2007
  • eagle338
    eagle338 Oct 26, 2007
    Feel free to ask if you need help locating the fuse..
Door lock is stuck closed cannot shut door?
Good Morning Richard, thank you for your inquiry!
Based off the information you have provided your Frigidaire oven door is stuck closed and you are unable to shut the door. You can disconnect power from your range for at least ten minutes and that will reset your oven. This may trick your door latch into opening.
You can also hold down the cancel or clear button for 10 to 15 seconds that may allow your door latch to release. Also attempt to hold down the light and cancel buttons. I hope this information has been helpful to some degree. -Matt
Mar 23, 2015 | Frigidaire Ovens
I have a GE wall oven JGRS14GEVIBB and the problem is that it heats up to the set degree level and then totally shuts down.
There could be a bad connection on the electronic control. Try pulling the connectors off and reinserting them. There may be a thermal breaker in the top but it shouldn't shut down the oven unless it is giong bad.
Nov 24, 2014 | Ovens
Hi, it won't cause your oven overheating by hanging loose. I think your thermostat is faulty. I don't suggest opening it to try and repair it yourself. If your tamper with the metal plates inside, your temperature will not be accurate as where you set it for 120 degrees Celcius or 248 fahrenheit it will meybe give you a true temperature of 220 degrees celcius or 428 fahrenheit which would be chaos. Rather rplace the complete thermostat unit.
May 03, 2014 | Bosch Ovens
Hotpoint oven display not working just clock flashing
Your electric stove has power through 220, wired separately from the rest of the outlets. Go to the breaker for this, shut down total power, and see if that helps. Sometimes it does not take much to reset.
Mar 05, 2014 | Neff U1661 Double circotherm super...
Door will not open and oven will not shut off
The door latch will open after the shut down, therefore go to the home circuit breakers and shut off the power to the oven. Wait a few minutes and try to open the door. If still locked, reset the power to the on position and see if the oven rest and shut down properly and the door lock released.
Dec 31, 2013 | Kenmore Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Please could someone tell me how to use the grill?
First things first, the grill only works with the door down. Directly you shut it, a microswitch operates and shuts the elements off. ( Of course the top oven operates with the door shut).
There are two options for the grill. Turning the control switch to the left operates the inner element only. Turning it to the right operates both the inner and outer elements together.
With either option, setting 5 (the max) has that option on full, whereas settings 1 to 4 switch on and off.
Nov 10, 2010 | Stoves 720EF Electric Double Oven
Fan won't shut off after oven cools down
Most fan ovens have a control sensor which allows tthe fan to operate even after you have turned the oven off to prevent overheating.
It sounds as if this sensor has stuck in the closed position thus leaving the fan running .
You will need to replace the fan control unit at the back of the oven.
Dec 31, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Whirpool double oven shutdown during self cleaning operation and now is completely dead and the top oven door will not open. I have checked the circuit breaker and it is in the closed position and power is...
Too bad someone didn't answer this sooner. Caused be poor air circulation in the unit. There is indeed a thermal fuse used in this unit. This problem has been around for a while and no real solution has been found. The closest "fix" is to remove the fuse, turn it around and only hook it down with the screw that faces the panel. The other screw hole is then bent to a 45 degree upward slant. This give the fuse a little breathing room.
Dec 17, 2007 | Whirlpool GBD307PDS Electric Double Oven
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
306 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
