Question about KitchenAid KERC507 Electric Kitchen Range
Replace fuse kitchenaide stove - KitchenAid KERC507 Electric Kitchen Range
Kitchenaid stove code f68
This stove should absolutely still be under warranty. I would start with calling the KA customer service. They are pretty good and will usually do all they can to help you. The number for them is:
800-422-1230
Jan 03, 2014 | KitchenAid Electric Stove Range...
My kitchenaid gas stove continues to try to ignite making popping sounds
Here You can see how to disassemble Kitchenaid cooktop. I replaced everything on this one, since I knew its a big job, decided to do everything at once. Problem is - cooktop is dead, no spark to any burner. I hope it helps! Thanks! How To Repair Whirlpool KitchenAid Stove Cooktop HD 1080
Apr 24, 2010 | KitchenAid 31 in. KGCS105 Gas Cooktop
How do I remove the built in oven to replace the
there are no internal fuses, chk your houses main power panel and stove plug to make sure you have 240 volts for proper unit operation
Nov 03, 2009 | KitchenAid KEBC107 Electric Single Oven
Same thing with my one and 1/2 year old KGSS907 series stove
Yes it is fixed. Did a temporary jumper of the over temp fuse to use the oven one night. Installed a replacement 130 degree fuse with a mica transistor insuator under it instead of being mounted directly on the back side of the oven. This raised the range to about 150 degrees.
Thanks for the help
Aug 25, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
F2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Inoperable KGRE801PBS00 Kitchenaid oven
1) unplug and turn your gas valve off
2) with a #2 phillips remove all the silver screw on the back of your stove (this will make is to you can remove the stainless splashguard)
3) there are several black screw holding on a removable (stainless) panel that covers the back of the stove - your culprit (thermal fuse) is under here).
4) on the back of the oven you'll see the back of a couple of fixtures (stove light, temp sensor etc). <-- do not touch these..
5) there is another attachment (attached with black #2 robertson screws).. it has two black wires plugged into it.. this is your thermal fuse - mine has a number 8300802 on it.
I had to replace this (18bucks) from my local hardware store. Unfortunately, these stupid ovens have this part recurring so buy a few.
At your own risk - when reinstalling, slip a little cardboard between the thermal fuse sensor (stainless flat side) and the stove.. you may save a few headaches..
this repair was an easy one compared to replacing the board on this stupid oven.. (i would not recommend buying one - typical north american engineering designed to keep the repair folks working)..
i guess you need to find a different way to screw the consumer eh KitchenAid? lol
have fun
CA
Oct 26, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
KitchenAid KERC507 Electric Kitchen Range Logo
53 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
