Question about Thermor Bios Digital Home Weather Station
Can't get the outside temperature
Still Reading indoor temp
Out do I get the outside temp back.
You have to remove all batteries, both outdoor and indoor. Install replacement batteries in the outdoor unit. Back indoors, install replacement batteries in the indoor unit and wait for temperature to be displayed. If nothing happens, the outdoor unit may have failed.
Jun 17, 2016 | Measuring Tools & Sensors
IT WORKS BUT AT THE CYCLE END SUPPLY COLD AIR IS IT NORMAL?
Most air cons now have temperature sensors all over the machine. When it reaches temp on heat cycle, the machine usually shuts down both indoor and outdoor units but the indoor unit will keep running for a few minutes with the fan on only to cool the indoor unit down. This prevents the unit reading the wrong temperature. It stops the sensor(s) reading the heat from the indoor unit rather than the heat in the air in the room.
Jan 04, 2016 | Heating & Cooling
My window unit has ice on the coils & vents and makes a "popping" sound when it shuts off. I have it set on 60o - the outside temp is 49o
Running this unit @ such a low indoor & outdoor temp. is going to need an ambient controller. It acts like a rheostat to slow the speed of the condenser fan to keep the refrigerant pressures up so that it doesn't freeze like you're experiencing. The ambient controller can either tie into the refrigerant system reading pressure, or a surface mount thermistor sensor on the exiting condenser coil line to read temperature.
Jan 22, 2015 | Heating & Cooling
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Low side and high side readings
pressure readings vary depending on temperature, humidity, and other factors such as coil condition (inside and outside coils) ducting, other mechanical issues. The is no absolute readings for any one type of system, that said a ball park reading with an outdoor temp of 90deg and an indoor temp of 78deg it would be around 65 to 70 psi low side and 150 to 210 psi high side.
Sep 21, 2011 | Ruud Matching Split Air Conditioner
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
Our new model #00592W1 includes a low temperature adaptor that plugs into the wireless sensor. Is it necessary to use this?
I found this on another Acu-Rite manual: In case temperatures fall below -4F, bring the wireless sensor indoors and use the included low temperature adaptor by routing the wire out through a soft seal opening such as a window or door. (That way the Wireless sensor is protected indoors in extreme temperatures. Low temp adaptor is used outside to observe temperature.)
Dec 12, 2009 | Acu-Rite Audio Players & Recorders
NOT COOLING PROPERLY. SUSPECT CHARGE SUPERHEAT TOO HIGH
take the temp and press reading as per manf. and cal actual superheat. what are the reading for amb, evap temp, pressures high low. Then adjust charge. you need to determine super heat based on dry bulb indoor and outside ambient the read suction line temp vs suction line pressure
Aug 09, 2009 | Goodman CLQ36AR49 Air Conditioner
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Thermor Bios Digital Home Weather Station Logo
Top Thermor Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Thermor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
