Question about Utilitech Plumbing
Utilitech .5-hp cast iron submersible sump pump float switch stuck in on position and pump runs every 10-15 minutes like a washing machine spin cycle
There is no on/off switch tried moving float around to reset it
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
  • 7 Answers
SOURCE: Appropriate size inverter for sump pumps
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
Posted on May 07, 2009
  • 850 Answers
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Posted on Jul 28, 2009
  • 3 Answers
SOURCE: won't spin
won't spin
Posted on Aug 23, 2009
  • 523 Answers
SOURCE: gould 1/2hp submergible well pump cycles on and
My first thought was that of a water logged tank which causes short cycling, from your notes the tank is good (the tank may be partially water logged though) If the tank is ok and your getting short cycling (and the switch is good) I would guess your check valve down the well has failed. As the pump creates pressure then shuts off the water may be going right back down the well causing the pump to cycle again. This could also account for the poor water pressure as the check valve may be stuck slightly open allowing the system to loose pressure but only allowing a small amount of flow by when running. There could be a leak within the pumps drop-pipe and your loosing pressure through this leak. I expect you'll have to have the pump pulled.
I hope this may have helped,
Tom
Posted on Oct 12, 2009
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
Aug 20, 2015 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
Sump pump does not go on all the time have to shake pipe to get it going so water doesn't overflow
There should be a float switch in the pit, sounds like its getting stuck and when you shake it it activates. Check the switch, the rod, etc.
Mar 01, 2015 | Utilitech 0.33-HP Thermoplastic...
Why wont the pump turn on
If the pump is plugged in through a float switch the switch may be bad- try plugging the pump in by just the plug for the pump itself if possible -if that works then you need a new float switch.
Jun 10, 2014 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Sump pump runs constantly
external float type? move float up and down- should shut off if down - if not - switch needs to be replaced
Dec 22, 2013 | Liberty Pumps 253 1/3 hp Cast Iron...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pump not working
If power is going to pump and float switch is good, motor has fried, time to get a new one.
Oct 07, 2012 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Flotec Float switch did not automatically shut off,enginburn out
Hi Lamont .. I would first check test the float switch and make sure that it is faulty, set it up in a tub of water and manually move the float switch. see if it cycles on and off. sometimes the float will get hung up on its support or on the edges of the sump pit. If the float switch is faulty then YES it can be replaced,. try a building supply store like home depot or the pl;ace where you got the switch originally.
Please Vote !!
Jun 01, 2010 | Flotec 13 Hp Automatic Submersible Sump...
1/3 hp wayne pedistal sump stoped working
yes there are brushes,, but there is also a shaft that goes thru the tube make sure it is not broke or bent,, it happens,, suggest to get a zoeller submersable pump its the best cast iron, float is attached to the unit, will fit in small pits, only 1 plug needed,, cost for pump 100
Dec 31, 2008 | SPV Wayne Pumps Spv500 1/3hp Cast Iron...
Plumbing Logo
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
